Peterbilt Specifications by Vin
Discussion in 'Peterbilt Forum' started by mocy, Sep 4, 2016.
  1. mocy
    mocy Bobtail Member
    I am looking to purchase a truck with the following Vin: 1XPADR9X3MD309231
    Where can I go to specfications - Engine, Trans, Axle ratio, Axle ratings?
    Thank you.
  3. Ridgeline
    22,704
    122,333
    The dealer. They have all the records you are looking for. They have what is called a build sheet which breaks down all the info.
    Bean Jr. Thanks this.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,567
    9,929
    Mar 30, 2014
    All you need to give them is the last 6 digits.
  5. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Here is a website you can put in your VIN and get some info about it. It won't give everything your asking for but some other interesting info. Like the other guys said just call a dealer and give the last 6 of your VIN.
    http://www.gates.com/catalogs-and-r...business-applications/vin-decoder/vin-decoder
    A5¢ Thanks this.
  6. pushbroom
    pushbroom Road Train Member
    1,788
    7,392
    Sep 1, 2012
    It has a series 60 engine shows 450hp but could have been uprated by now. Fuller RTO-14613 trans. Hendrickson RT400 suspension. Cant seem to find rear axle ratios. It just lists off the serial numbers and nothing else. Hope this helps!
  7. Belials
    Belials Light Load Member
    232
    216
    Jun 10, 2014
    No it doesn't.
    PM me and I can give you most of the information.
  8. ThatAmberChick
    ThatAmberChick Bobtail Member
    4
    Jun 26, 2020
    I need a build sheet for an old peterbuilt 359 series from 1986, a 1987 377 series, And a 1990 378 series... desperately been trying to find the build sheets with no luck, dealers won’t give me up either... any ideas?!?!
    NightWind Thanks this.
  9. Belials
    232
    216
    Jun 10, 2014
    The only way to get a "build sheet" is to order them. The build sheets are electronic, meaning we can't provide them to you. We look them up online, and printing them would be thousands of pages.
    For older trucks, it's even harder.
    If you want one, you need to ask the dealer to order you one. They're pretty expensive. They're also pretty difficult to understand if you don't know what you're doing.
  10. NightWind
    NightWind Road Train Member
    2,718
    19,169
    Nov 11, 2006
    Sunny South, AL
    I called Peterbilt in Denton TX told them what I wanted. Gave them the VIN They emailed me the build sheet and electrical schematics for free. Just need to call and ask. My Peterbilt dealer was as useful as teats on a boar hog.
    Bean Jr., spsauerland and 650cat425 Thank this.
  11. JackZ
    JackZ Bobtail Member
    24
    6
    Jul 7, 2011
    Winston-Salem, NC
    NightWind:
    What year is your truck and do you remember the name of the person in Denton that you talked to about getting the build sheet?
