peterbilt trailer valve issues
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Allnotch, Aug 22, 2020.
  1. Allnotch
    Allnotch Bobtail Member
    13
    5
    Aug 22, 2020
    16 pete 389. The tractor valve pushes in fine, the trailer valve will not stay locked down. If I hold it air flows out the line. I took the line off behind dash and it pushes air out if I hold it down. I replaced the inside valve with the same results. The one I replaced it with was a used unit. Any ideas.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    If you have an air leak somewhere fix that before working on the control valve. Probably requires two people to find the leak.
    spsauerland Thanks this.
  4. Allnotch
    13
    5
    Aug 22, 2020
    No air leaks anywhere.
  5. Goodysnap
    Goodysnap Road Train Member
    3,747
    9,110
    Jul 12, 2017
    So you changed the MV3 dash valve and the red knob wont stay in, Correct? If you block the red trailer air supply line or cap it does it still not stay in? I think your going to be looking at a defective Tractor protection valve.
    pushbroom, spsauerland and 650cat425 Thank this.
  6. Allnotch
    13
    5
    Aug 22, 2020
    Yes you're right. I have hooked an air line to a trailer, an airline to air up tires and left it open and the trailer valve still doesn't stay engaged. It flows air out of it for like 10 seconds if i hold it in. I thought the same thing on tpv but I replaced it today and still the same thing.
  7. Goodysnap
    3,747
    9,110
    Jul 12, 2017
    Ok but if you block the red line off to the trailer , dummy gladhand plugged. Does the red knob stay in with no leaks on its own.
    If you then create a leak or open the line, it should pop. This is normal. You wont be able to leave the red knob in with a leak. Break away protection is working correctly.
    AModelCat, tj379 and 650cat425 Thank this.
  8. Allnotch
    13
    5
    Aug 22, 2020
    No it will not. It won't stay in.
  9. BoxCarKidd
    4,525
    6,586
    Aug 26, 2014
    Is the hand valve fully released?
    Goodysnap Thanks this.
  10. Allnotch
    13
    5
    Aug 22, 2020
    Yes I checked that today.
  11. Allnotch
    13
    5
    Aug 22, 2020
    I mean there's what the dash valve, tpv and the foot valve. No leaks nothing. Truck was fine when parked and it sat for like 3 months and here I am. I don't have to funds really to take it to pete. I'm going to trough a foot valve in it tomorrow morning and probably return the tpv.
