Physical abilities test in orientation?
Discussion in 'Knight' started by Diesel73, Jun 5, 2022.
  1. Diesel73
    Diesel73 Light Load Member
    94
    191
    Apr 18, 2022
    Does Knight do a physical abilities test in orientation? If so, what is it?
  3. VA CDL Holder
    VA CDL Holder Medium Load Member
    592
    1,006
    Jun 14, 2011
    Yes they do. As part of your physical, you will perform a test that simulates the pulling of the kingpin release handle. You will lift, I think 70 pounds to shoulder level and place it on a shelf. You will simulate getting into and out of the truck close to 30 times. The kicker is lifting from the floor, I think 30 pounds and walking like 10 feet, turn around walk back and safely lower the weight to ground level, pick it up again and repeat the process, if I recall correctly 6 times.
    I've done this test numerous times when hired out of Phoenix. As always, your experience may be different!
    Diesel73 Thanks this.
  4. TB John
    TB John Company Shill of BYOB & CBD
    3,493
    8,508
    Dec 28, 2008
    I think they also check your heart rate at the beginning and end of the test session.
