physical requirements for flats
Discussion in 'Roehl' started by avenger79, Sep 5, 2013.
  1. avenger79
    avenger79 Medium Load Member
    381
    175
    Sep 13, 2010
    WIS
    Roehl used to have a pretty good description of Flatbed training and physical requirements on their site. Didn't see it there anymore. Anyone have some specifics as to what you need to be able to do in order to go flat?
  3. Rascal1953
    Rascal1953 Bobtail Member
    28
    25
    Feb 20, 2011
    Morrison, Tennessee
    Well, Sir, You don't have to be in combat shape to flatbed. The most physical aspect of flatbedding is tarping the load in inclement weather. Basically, if you have use of all your limbs, and can climb a little, have average upper body strength, and a better than average capacity for common sense, you will have no trouble flatbedding. I'd stay the hell away from anybody who would base a hiring decision on how fast you can secure and tarp. In actuality, it takes a little time to do it right.
  4. avenger79
    381
    175
    Sep 13, 2010
    WIS
    true true. mostly I'm worried about lifting requirements. It's been a while since I had to lift and carry anything of considerable weight. I know TMC says you have to be able to lift and maneuver 120lbs. I prob still could but wouldn't be easy anymore like it used to be. LOL
    Skydivedavec Thanks this.
  5. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    my tarps weigh 70 pounds. i don't think i could lift and maneuver 120 lbs.
  6. avenger79
    381
    175
    Sep 13, 2010
    WIS
    now 70 I could do, chicken feed bags weigh 50 and I carry those from the driveway down to the coop.
  7. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Good balance is also good. A flatbed driver ain't no good falling off the load or deck.
  8. avenger79
    381
    175
    Sep 13, 2010
    WIS
    no points for sticking the landing i take it? LOL
    balance I'm good with. agility and such would actually be a strength of mine
  9. sjtrucker
    sjtrucker Light Load Member
    192
    66
    Nov 5, 2007
    Hayward WI
    When you show up for orientation or RDTC whatever one you are doing, and it comes time for the test, they will take your blood pressure, heart rate, and weight/height to establish a base line. After each exercise the will check your heart rate again. They have a pre established rate that you can not exceed for your height/weight/age. As far as the exercises you will preform for flatbed, you will pick up a steel tarp approx. 60 pounds and carry it 48' turn around and carry it back. You will climb to the top of a 16' ladder, you will pull on some kind of weight device simulating landing gear on a trailer. you have to be able to pull a certain amount of weight and hold it for like 5 seconds, I cant remember, but its not hard there are some other things like squatting under a trailer and lifting a 50 lb bag above your head but its all easy if your some what in shape
    Truckie83 and avenger79 Thank this.
  10. avenger79
    381
    175
    Sep 13, 2010
    WIS
    Perfect!! thanks much for the response. That all sounds pretty do able
  11. technoroom
    technoroom Heavy Load Member
    830
    459
    Nov 8, 2012
    For what it's worth, I've come across lumber tarps that are well-north of 100 lbs. Fortunately they don't make you carry one of those on the test where they monitor heart rate.
