Plastic fuel tanks
Discussion in 'Experienced Truckers' Advice' started by uplander, Dec 16, 2017.
  1. uplander
    uplander Light Load Member
    128
    224
    Jan 9, 2014
    Thinking of ways to reduce the weight of a truck.
    I thought why are fuel tanks metal and not plastic
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I got a good one, ELECTRIC AUTONOMOUS TRUCKS would take care of all of it. Gets rid of the excess weight of a lard ### driver and the motor and the fuel tanks.
  4. AModelCat
    164,494
    The weight savings would be very minimal. I can move a 90 gal aluminum fuel tank around pretty easily myself. Plus with plastic being as flimsy as it is and how its affected by heat/cold you'd need a pretty rigid and sturdy bracket to keep it from sagging out around the j-brackets and straps. Kinda defeats the purpose.
    Toomanybikes, SingingWolf and mhyn Thank this.
  5. AModelCat
    164,494
    Seems legit. Just replace that heavy engine, transmission and fuel tanks with a few thousand pounds worth of batteries.
    tscottme, aussiejosh and mhyn Thank this.
  6. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    Because repeated hot and cold makes plastic brittle.
    You obviously have no experience with plastic boat tanks.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    No man, that wont work. Remember that fuel tanks must retain integrity during a drop of a certain height when filled.
    If I was hired and saw plastic fuel tanks you will find another driver to replace me that same day.
    tscottme and SingingWolf Thank this.
  8. Ezrider_48501
    3,845
    5,134
    Apr 2, 2011
    bismarck, nd
    i would think aluminum would be less likely to puncture in a accident as well. also i have replaced tanks on a truck before empty they really are not that heavy.
    Toomanybikes and SingingWolf Thank this.
  9. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    Lol keep thinking... the weight is gonna be the same maybe couple hundred difference.
  10. gpf87
    gpf87 Heavy Load Member
    765
    883
    Feb 2, 2017
    They're not even that heavy . You know they're made of aluminum right ?
    The diesel is the heavy part at around 7.25 lbs per gallon which is actually less than the weight of water.
    If you want to save real weight you need to spec a different truck . You ever see those short frame,extra short hood trucks with one fuel tank ?
  11. gpf87
    765
    883
    Feb 2, 2017
    And this truck could be even lighter with super singles
