Please help
Discussion in 'Ask An Owner Operator' started by Tyrion, Aug 31, 2018.
  1. Tyrion
    Tyrion Bobtail Member
    9
    When taking Class A CDL does your truck alone have to weight 26001 or is that with trailer hooked up with it
  3. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Well, a standard over the road semi, by law, can not weigh more than 12,000 pounds, 12,500 if you have an apu unit.
    So, it would have to be truck and trailer.
  4. nikmirbre
    nikmirbre Road Train Member
    5,558
    10,254
    Jul 27, 2011
    High Point NC
    12000 lbs??? I would venture to say all otr standard trucks with a sleeper weigh at lease 16-17000 lbs.....
  5. SteveScott
    SteveScott Road Train Member
    4,897
    16,808
    Nov 10, 2015
    He's not asking about the weight limit on the steer tires, and the APU exemption isn't allowed in every state.
    Oldironfan and CrappieJunkie Thank this.
  6. SteveScott
    4,897
    16,808
    Nov 10, 2015
    Not exactly sure what you're asking, but a truck and trailer combined weight with full fuel tanks is more like 30,000 to 35,000 pounds if it's a sleeper truck.
  7. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    Class A allows you to operate a vehicle in excess of 2600 pounds either singly or in combination
    Oldironfan Thanks this.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Combined weight has to be more than 26,001 lbs with a trailer more than 10,000 lbs to qualify for a class A.
    That is weight ratings, not actual weight.
    What were you hoping to use? More than likely we can tell the pros and cons of any combo. You might have to worry about restrictions like 5th wheel and air brake depending on unit tested with.
    Oldironfan and jammer910Z Thank this.
  9. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    My brand new plasticadia weighs almost 21000 bobtail.
  10. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Is that will full fuel and def?
    And how many gallons of each?
  11. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Mine is 19.900lbs
    Full 120's and def and apu.
    I think my def tank is 30gals
