Please please I need help in CDL school
Discussion in 'Questions From New Drivers' started by DesperateCDLstudent, Apr 20, 2022.
  1. DesperateCDLstudent
    DesperateCDLstudent Light Load Member
    51
    54
    Apr 20, 2022
    I’m 3 days in. Today I was ready to explode after performing well the beginning of the day and tanking at the end. I also feel like everyone expects me to be better than I am by now since it’s a small class size. I need help or just understanding on a few topics if anyone at all wants to chime in.
    For reference, prior to this I never drove a manual and never drove a semi (only automatic box trucks occasionally). So for me it’s sort of like I’m learning the concept of a manual transmission, how to operate this 10 speed with a M pattern (found that out on YouTube), and also how to drive a semi.
    1. This is just for clarification because I’m not sure if anyone I’ve asked has been understanding my question. I *can* hit the clutch and brake at the same time to stop, PRIOR to shifting to neutral? Obviously not the brake alone. This would also be slow speeds like 3rd gear or backing.
    2. I suck at taking off from a complete stop. I now know to raise the clutch to the same height as the brake, but I can’t seem to get a smooth takeoff when I engage the accelerator and release the clutch slowly. What am I missing?
    3. I can downshift like a beast. Clutch, neutral, rev, float to gear. Easy money. But I occasionally have trouble upshifting floating gears and not due to not knowing their positions. I feel like I rush it sometimes and miss the gear. When floating, can I hesitate for a split second while in neutral? So like upshift to neutral, pause, push right and up to 4?
    4. How the heck do you 90 degree back? This was my first time ever backing up and I got the straight backing thing or whenever down but that 90 degree is crazy.
    Boondock and austinmike Thank this.
  3. pumpkinishere
    pumpkinishere Heavy Load Member
    945
    4,986
    Apr 21, 2021
    You are only 3 days in, give it time, seriously. When getting my cdls in my class we had a couple of foreigners who could barely speak English and took extra time to get them prepared for the testing. Trust me your school will work with you. There is a trick on the 90 degree back and if you instructor is any good he will give you the exact points to look at while doing the backing. If I remember correctly like when turning the wheel all the way to the right as soon as you see the leg of the landing gear in the mirror then you turn your wheel all the way left until you see landing gear leg. Something like that. Ask your instructor to be sure but there are focal points when doing that backing. The crazy thing is once you get your license you will almost always not get yourself into those situations where you will ever need those backings to park your semi. Don’t sweat it you will be just fine. Seriously.
  4. austinmike
    136,819
    When I was in school I questioned my decision to do it. It takes time to get the hang of shifting. It can be intimidating. Take your time and listen to your instructors. Best of Luck -
  5. DesperateCDLstudent
    51
    54
    Apr 20, 2022
    Thank you pumpkin and Austin. I tell myself that it’s only a few days but it feels like they’re looking at me like I should have been driving OTR since yesterday.
    Coffey, Boondock and austinmike Thank this.
  6. pumpkinishere
    945
    4,986
    Apr 21, 2021
    Understandable. I felt the exact same way. Just listen to the instructor and he should give you pointers on the backing. On taking off if you have the truck in gear let off on clutch slowly, let clutch all the way out and the truck will go. It is not like a car where you have to let off clutch and gas at the same time. Just like if your on a hill, you just let off the clutch and the truck will engage and go forward you don’t have to worry about the semi rolling backwards if you just let off the clutch and the truck is in correct gear. So when I went to school, with a trailer they would always have us take off in 4 th gear. Next time you are in truck put it in 4th gear and let off clutch you will see the truck will roll. So that should help with rough starts for you.
  7. pumpkinishere
    945
    4,986
    Apr 21, 2021
    I need to word that last post a little better. If you are on a hill you have your brake pedal pushed, your in gear with foot on clutch. Say the light turns green you start releasing the clutch ( at a sweet spot the releasing of the clutch a tad bit will hold your truck on the hill, the light changes and release the clutch all the way and your truck will go.) Still not the best explanation but keep in mind you truck can roll backwards but keeping foot on brake and holding in clutch will keep it from doing so. I’m hoping someone else comes along here and will better explain it to you. Just keep in mind the clutch on a semi is nothing like the clutch in a car. Next time behind the wheel put truck in gear and let off on clutch and it will take off.
  8. leviant0107
    leviant0107 Medium Load Member
    307
    209
    Oct 24, 2021
    Detroit, MI
    Just relax my man. You got this, take your time and breathe. I was slightly nervous the first time I took that 48’ flat on the road. You’ll be okay!
  9. DesperateCDLstudent
    51
    54
    Apr 20, 2022
    I’ve seen that in videos but it stalls unless in reverse. I’ll ask about starting at a higher gear. I’ve seen videos where other schools start them out in 5th gear, and it rolls.
    It’s very frustrating because I know exactly what to do and how to do it, but those 4 questions compound and make things difficult for me. If I can get rid of the rough takeoff and the clutch/brakes question that’ll solve 90% of my issues. Because let’s say for the 90 degree backing, if I want to stop to make quick corrections, I shift to neutral, then brake. By then I’m messed up.
    Boondock Thanks this.
  10. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    You shouldn’t have to touch the throttle when taking off from a stop. If you do then you are either in too high a gear or maybe something wrong with truck? What kind of truck are you in?
    Also, probably shouldn’t be worrying about floating gears in cdl school. Aren’t they teaching you to double clutch?
    Coffey, AModelCat and Boondock Thank this.
  11. DesperateCDLstudent
    51
    54
    Apr 20, 2022
    It’s an older International. Nope no double clutching. Being taught to float and hybrid downshift (from what I researched online). We start in 3rd gear. Taught to slowly press gas pedal while letting up off clutch slowly at same rate. Works for other students there. Not for me.
    Boondock, Kyle G. and Rideandrepair Thank this.
