Popping noise, driver side steer
Discussion in 'Freightliner Forum' started by Irishblood_83, May 8, 2021.
  1. Irishblood_83
    Irishblood_83 Bobtail Member
    22
    7
    Jan 11, 2021
    So for about 4 or 5 days now, I've been checking all around the drivers side steer tire / hub for any obvious issues that could cause such a weird noise and I can't find a single thing wrong. If I'm cruising straight there's no noise, but slight curves in the road can make it appear, and more often than not when I'm braking. I thought possible king pin or leaf spring bushings? Truck only has 50k on it, and bushings look fine from what I can see. Any help would be appreciated. Thanks guys.
    Trucker61016 Thanks this.
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Loose U bolts, have front spring shackles been greased, have taken truck back in for alignment after suspension settled
    Usually get them in after the first 5k miles to have suspension components retourqued and alignment done. Alignments from factory are not all that accurate. Sounds like something loose or shackle pins haven’t been greased
    Rideandrepair Thanks this.
  4. Arctic_fox
    4,508
    25,456
    Sep 16, 2016
    Yup. When i got my pete it had that same sound. Turns out the grease had dried up from sitting for a year. Once i got new grease on it vanished after about an hour when the movment worked it in and hasnt come back.
  5. 201
    201 Road Train Member
    12,771
    26,279
    Apr 16, 2014
    high plains colorado
    Popping noise in the front was always dry spring shackles. Good luck getting grease in there if they're dry. Sometimes, warming them up with a torch slightly works.
    shatteredsquare Thanks this.
