popping noise from front spring
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Jhimely23, Dec 27, 2015.
  1. Jhimely23
    Jhimely23 Bobtail Member
    27
    9
    Nov 1, 2014
    Is this something that's an easy fix.
  3. oilfield driver j
    oilfield driver j Bobtail Member
    33
    7
    Apr 12, 2015
  4. Jhimely23
    27
    9
    Nov 1, 2014
    What has to be done?
  5. oilfield driver j
    33
    7
    Apr 12, 2015
    Looks like the bushings need replaced.
    Day or two maybe? Kinda hard to tell. Looks like a lack of maintenence
  6. Jhimely23
    27
    9
    Nov 1, 2014
    Ohk, cool. Yea I just got the motor rebuilt and haven't had a chance to clean the oil off.
  7. KAK
    KAK Medium Load Member
    518
    2,073
    Feb 10, 2012
    Ne
    Bushings look VERY dry. Prolly need new ones and keep them greased !!!!!
    oilfield driver j Thanks this.
  8. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I would try putting a little heat on them and see if they will take grease. Or take the grease gun with you and after you put some miles on for the day. See if they will take some grease.
    KAK Thanks this.
  9. AModelCat
    164,535
    Grease is cheap. Those bushings look like they're in desperate need of it.
  10. Also the popping is your leaf spring coming out of alignment. Have a welding shop put a C clamp on edges to straighten, then wrap with steel band.
    Or. Two flat pieces of steel drill two holes on each end of steel, put bolts on either side of leaf spring and squeeze together. So one plate below leaf one above.
    The stock factory leaf spring guids wear out or just fall off.
    Ozdriver Thanks this.
  11. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    If its a threaded pin and bushing type you can change it in a hour, but this one kind of looks like a regular bushing or a Horton needle bearing set up, still would take about an hour per pin. I like the threaded pin/bushing type (KW) can hammer them out and in, all 6 in 5 hours.
