Possible freight damage-advice needed
Discussion in 'Freight Broker Forum' started by ThreeM, Nov 24, 2015.
  1. ThreeM
    ThreeM Light Load Member
    56
    Mar 30, 2014
    One of our customers sent a load of trees and the company we used took 7 days to deliver them(truck broke down , then driver was running late and all sorts of excuses), the trees were loaded on a flatbed. Now the customer is asking for advise, should he make a tentative claim just in case any trees show damage later on due to being on the truck for so long( transit time is 1 day, driver got to destination exactly 1 week after that ). BOL was signed when receiver accepted the trees but now the customer is worried they might claim some of the trees were damaged and might not pay him.
    Any advise would be helpful.
    Thanks
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Live trees? Sitting on a flatbed wouldn't be any different than sitting on the ground
    ThreeM Thanks this.
  4. Karen O
    Karen O Bobtail Member
    26
    23
    Jul 25, 2015
    Gilbert, AZ
    Why do people even sign the BOL? Seriously, it is there to protect the driver and customer. You signit.... it should be over. I am hearing this more and more often. And yes this is transportation, things happen often that are out of the drivers control. If the load , whatever it may be, needed to be there and was delayed for whatever reason... then another truck should have been dispatched to "rescue" the load and get it to it's destination. Customer should have done a thorough check upon delivery for any damages. I see the persons point but isn't this the reason we have BOL's. Grateful the guys I work with have gone electronic. Rant over.
    ThreeM Thanks this.
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Any Penalties from the Consignee for a very late delivery?
  6. ThreeM
    56
    Mar 30, 2014
    consignee accepted the load and signed the bol, customer is worried they might not pay for some of the trees if they show a damage later on,
  7. Mark Kling
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    I know that, but since it was a week late they might be penalties involved if in the contract.
  8. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    Clean BOL. If there is damage later on there is no way to lay that on the delivery.
    Like its hard to accept a load that shows no damage, and then say wait, the damage is going to happen later.
  9. Urziel
    Urziel Light Load Member
    106
    56
    Dec 9, 2013
    They could claim hidden damage but the reality is they need to be checking the cargo as it comes off the truck. The greater the distance between delivery and claim makes it look suspect. The customer should always check cargo before signing the BOL.
    Karen O Thanks this.
  10. glockwise
    glockwise Light Load Member
    253
    225
    Apr 24, 2014
    FYI- Trees are exempt
    It may come down the small claims court in your area, assuming you have a clause in your agreement stating were issues are to be taken up. Otherwise it could come down to their jurisdiction in which case you will pay up as it is usually cheaper than traveling.
    It doesn't appear as though you are familiar with things like shipper load and count, hidden damage, items of a contract, or the Carmack Amendment? I would probably start there.
    Without knowing the details of your contract with the carrier, especially the limits and over rides of Carmack or how the transportation of exempt items are handled,or your amendments of the contract (rate con), or your statement of position with your customer (it sounds like you hold a position of intermediary as they are seeking advice on a claim like it should be), it would be impossible to offer accurate advice on this movement.
    All exempt items should be hauled without extending credit, ie COD. Brokers have screwed this up as it was intended to be handled due to the complexity of the products and their susceptibility to spoilage/damage because they couldn't figure out how to get a cut on a COD shipment without the carrier figuring out their greedy cut. Instead of invoicing the customer for $x and then having the customer pay the carrier the remainder at delivery. And most carriers aren't versed enough to know where to look or how to wade through the red tape.
    Good Luck
    oldtrucker66, ThreeM and Karen O Thank this.
  11. kwswan
    kwswan Road Train Member
    2,019
    11,010
    Jul 26, 2009
    mcminnville,tn.
    Depends on whether they were balled & burlap or container trees. B&B,they will probably be ok,containers maybe not. I haul trees regularly & if I have a breakdown that I see is going to take more than a day or so to fix then I will get someone else to deliver them.Sitting there for a week is really unexcusable.
