Possibly bad egr
Discussion in 'Volvo Forum' started by dismag, May 5, 2018.
  1. dismag
    dismag Bobtail Member
    37
    Jul 20, 2012
    Good day everyone. what is the symptoms of bad egr valve for volvo d-13 engine? What I have is rpm jumps up and down at idling. I suspect egr valve is sticking.
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    this is a possibility most of the time this happens is actually the turbo waste gate messing around. you will have a code if the egr is sticking or stuck open for egr flow being to high coupled with a really lazy truck regen temps will never make up to actuall spec and fuel economy down the drain.
  4. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    If this were a DD 15/13 it would be the fuel quantity valve.
  5. dismag
    37
    Jul 20, 2012
    turbo was replaced recently and actualy it start doing that after
  6. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    try to calibrate the VGT or remove and check the stroke make sure full stroke is going on i've had a few times that i have put a turbo on and it has been bad from the get go. make sure the stroke checks out fully
    dismag Thanks this.
  7. dismag
    37
    Jul 20, 2012
    I will do it tomorow thanks
