Power steering fluid
Discussion in 'International Forum' started by me myself and I, Mar 14, 2025.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    I was going to use DOT4 on my '20 LT.
    But the part guy at the dealer where I got filter for it told me not to. So what do I use?
  3. AModelCat
    164,481
    Most trucks seem to use either Dexron 3 or engine oil. What's your owner's manual recommend?
    DOT 4 brake fluid is not petroleum based. Not compatible with oil.
    Arctic_fox Thanks this.
  4. Arctic_fox
    4,503
    25,391
    Sep 16, 2016
    Check your manual or call your manufacturers dealer of your choice. Give them your vin and they can tell you what to add.
    AModelCat Thanks this.
  5. 201
    201 Road Train Member
    12,754
    26,240
    Apr 16, 2014
    high plains colorado
    We always used ATF, or that fancy store bought P/S oil,,,that's mostly ATF,,;)
  6. Ridgeline
    22,723
    123,063
    Yeah atf, it has the right additives but just dyed to make it look special,
    201 Thanks this.
  7. me myself and I
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Never mind. It was a brain fart( or old age).
  8. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    In case anyone wants to know, this is from the LT Owners manual;
    Steering System
    Approved (Power Steering Fluids)
    ATF Fluid (Approved for
    Use in Power Steering
    System
    Fleetrite® P/N FLTPSDX3Q (MPAPS B-6822
    Specification) or Equivalent (Must Meet TES
    389 / Dexron III Specification)
    -40°F to 92°F (-40°C to 35°C)
    Power Steering Fluid Fleetrite® Power Steering Fluid P/N FLTPSF32
    (MPAPS B-6811 Specification)
    -24°F to 90°F (-33°C to 32°C)
    Engine Oil (Approved for
    System
    Fleetrite® P/N FLTL15W40CK4G (MPAPS B-21
    Specification) or Equivalent API CK-4 15W-40
    Motor Oil
    18°F to 108°F (-10°C to 43°C)
    NOTE: The power steering system is filled with ATF fluid at the factory.
    Texan4Life Thanks this.
  9. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    We always used AW 32 hydraulic oil.
