Power steering issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Waddell1975, Jun 8, 2023.
  1. Waddell1975
    Waddell1975 Bobtail Member
    Carrollton georgia
    Replaced power steering pump, hoses, lines, reservoir and gear box and still over heats. Was instructed to use oil instead of power steering fluid and told it wouldn't create that issue. All these things are new and still over heats. Any suggestions
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    If you changed out the reservoir, did it have an oil filter in there? And if there was, did you change that?
    Rideandrepair and jamespmack Thank this.
  4. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    What is this on ? And every system has a filter as asked in the post above did you change the filter ?
    I mean it sounds like you just started throwing parts at it
    It very well might be you have a internal leak in the the steering cylinder its self which might cause the oil to over heat ..
    More info would be helpful
    Rideandrepair Thanks this.
  5. AModelCat
    164,173
    Power steering cooler on the truck? Dirty?
    @jamespmack mentioned a long time ago about a corroded ground cable causing the electrical system to ground using the hoses.
  6. jamespmack
    216,404
    Flow restriction. I question filter change also.
    Seen it on FL, melting High PSI hoses.
    We need more info.
    Rideandrepair and AModelCat Thank this.
  7. Ridgeline
    22,713
    122,718
    What kind of oil?
    Not motor oil?
    Use a good hydraulic or AT oil.
    Rideandrepair and Last Call Thank this.
  8. D.Tibbitt
    156,495
    Synthetic atf I all I use in it.. Like 40 dollars a gallon at Napa. Each drop of that #### must be worth like quarter atleast. Don't spill any.
  9. Last Call
    7,568
    45,912
    Mar 15, 2021
    Most all the newer systems recommend using hydraulic oil
    If its a older system I would stick with ATF myself
    Rideandrepair and D.Tibbitt Thank this.
  10. jamespmack
    216,404
    Almost all manufacturers have went to engine oil.
  11. AModelCat
    164,173
    I've only ever seen engine oil or Dex 3 used in power steering.
