Power steering issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Waddell1975, Jun 8, 2023.
  1. 201
    201 Road Train Member
    12,771
    26,276
    Apr 16, 2014
    high plains colorado
    I'm curious what is considered "overheating"? Does it get so hot the oil boils over? I think P/S systems, like all hydraulic units, run warm. I always ran ATF and on older trucks, I don't recall a filter on the P/S.
    Rideandrepair and jamespmack Thank this.
  3. AModelCat
    164,604
    Filter's in the reservoir.
  4. jamespmack
    216,478
    Most anything after 2000ish. Went to straight 15w40. I don't exactly have a answer why. I didn't see a problem with either.
    Rideandrepair and D.Tibbitt Thank this.
  5. D.Tibbitt
    157,046
    the resevoir on my peterbilt says only use dexron III . didnt know u could use regular 15-40 woulda been much cheaper then that atf
  6. jamespmack
    216,478
    Well that's a surprise to me. My 2000 I switched to 15w40 years back when I had system torn down.
    Like I said, I can't exactly give a better answer. On how or why. Sorry, and I have experienced no issues. Maybe other know more. It was pretty standard practice in my experience.
    D.Tibbitt and Rideandrepair Thank this.
  7. Rideandrepair
    17,550
    56,868
    Aug 8, 2015
    I always thought it was the older Trucks that used motor oil. Not all, but some. The idea was if it leaked into the engine, it’s only oil. I always used the latest greatest Dextron. To me hydraulic oil makes sense. Never heard of a PS cooler.
    D.Tibbitt and jamespmack Thank this.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    I'am not a expert on all the systems .. the Peterbilt's are what I'am most familiar with
    The older systems like on the 359's & early 379's All recommended the use of ATF
    The later 379 & 389 all Recommend Dexron III just rebuilt a system on a 07 379 last week the parts person at the Peterbilt dealer said ( some shops and customers use hydraulic oil. But our shop use's Dexron III
    Just like what @D.Tibbitt said there is a sticker.on alot of Reservoirs on the Peterbilt's I've been around that says Dexron lll
    1 thing is for sure every system has a filter .. that is a fact that was a Discussion on TTR a couple weeks ago about that
  9. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Gear and pump manufacturers offer multiple fluids that are approved for use across many applications. I too remember many older trucks with engine oil, especially twin gear systems with the larger reservoirs.
    I think ATF is a good choice especially for colder climate.
    Back in the 90s we had a Chevy WT with 5speed trans that failed early in life. Local rebuilder told us to switch the lube from ATF to 10w30. Never a problem after and it shifted so much better than it ever did from new.
    I don’t think the fluid type will fix the OPs issues, agree we need more info.
    Good discussion….
  10. Big Road Skateboard
    7,091
    40,179
    May 2, 2021
    How is it overheating? What are the symptoms? I've seen bad ground issues use the steel braided pressure hose as a ground. Burnt up the hose over the course of a day
  11. AModelCat
    164,604
    IIRC Dexron 3 is equal to about 8 weight engine oil. It will flow a lot nicer than 15W-40 in the cold.
    I was told a long time ago that if you mix ATF with engine oil in the power steering it'll take out seals. No idea how much truth is in that and I've never verified it. Could just be an old wives tale for all I know.
    jamespmack and Rideandrepair Thank this.
