power steering problem 2001 pete 379
Discussion in 'Trucks [ Eighteen Wheelers ]' started by johnjohn1984, Jan 28, 2020.
  1. johnjohn1984
    johnjohn1984 Bobtail Member
    7
    Jan 28, 2020
    i have a 2001 pete 379, i recently changed out the power steering pump and also steer gear and have hard steering. seams like a lot of steering wheel kick. the list of things ive done with in the last six months...new king pins with load bearings, new steer leaf spring bushings with pins, 3 axel alignment,
    if im on a nice highway it drives fine but the moment i get on a rougher road it has a lot of steering kick, almost a real hard time keeping it stright. any help would be appreciated, thanks
  3. Chubby Fly
    Chubby Fly Medium Load Member
    569
    796
    Nov 25, 2019
    Should be an easy thing to pinpoint. I have a 02 pete 379. When you say "kick" are you saying its a kick where you feel hydraulics fighting you? If so, it has nothing to do with kingpins or alignment. Or is it bump steer? Where you hit a bump and the steering wheel pulls to side of bump? How is your steer assist cylinder?
    johnjohn1984 Thanks this.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I had a rusty u-joint in my steering shaft, replaced the shaft that had greaseable u-joints-problem solved.
  5. johnjohn1984
    7
    Jan 28, 2020
    thanks for the reply. yes when you hit a bump or any uneven surface its hitting and puling the wheel. sorry but i dont know what t steer assist cylinder is. all i know i have a
    is the steer box and power steering pump.. thanks
  6. johnjohn1984
    7
    Jan 28, 2020
    thanks for the reply, ive checked the steering shaft and the u-joins and they all seam fine and greased.
    Bakerman Thanks this.
  7. Chubby Fly
    569
    796
    Nov 25, 2019
    steer assist is hydraulic cylinder mounted on passenger side
  8. johnjohn1984
    7
    Jan 28, 2020
    mine does not have that on the truck. should it have one? thanks
  9. Chubby Fly
    569
    796
    Nov 25, 2019
    im not sure my friend. maybe it was an option on my truck. I wish i could be more help. I never ran into this issue. You stated you have new steer gear box and a new steering pump. That has me baffled. should be running good once air pockets are out
  10. johnjohn1984
    7
    Jan 28, 2020
  11. johnjohn1984
    7
    Jan 28, 2020
    agreed! i dont know what else it could be but a friend told me to put 15w40 in it and it worked good for a few days then went back to hard steering wheel and bump steer ect ect. only other thing i can thinbk of is try using atf and changing the filter out again and see what happends, thanks
    HP510 and Chubby Fly Thank this.
