TRW recomends to use brlck between frame rail and tire becouse there are small valves inside steer box that drains pressure in lock position.
In normal operation steer box do not use full power (pressure) of pump so I sugest problems inside steering box, I think bad valve unit. It is available as spare part, but look for good workshop and follow the manual
Power steering pump question
Discussion in 'Freightliner Forum' started by tntruckdriver, Nov 4, 2012.
Page 2 of 3
When filling a dry system after testing or repair, never start the engine until the system is full of fluid without air pockets. Do this by filling the reservoir and bumping the key or rotating the engine to remove air pockets and refilling until fluid level remains full. When pressure is low or erratic, look for foam and air bubbles in fluid first.Last edited: Nov 6, 2012
usually to remove air from PS fluit it is enought to turn steering wheel from lock to lock 3-4 times. If you use modern ATF as PS fluid, foam is low.
I have never had a problem on any power steering unit with bleeding it out by turning it left and right. In fact most manual tell you to do this. Start by filling it up to the marks. start the motor and turn left and hold hard for 10 seconds than turn right and hold again hard for 10 seconds. normally this take 2 sets to complete. yes a kinked line will make it hard to turn. also you may want to check the steering box to make sure there is no blockage in it. good luck
Was this a TRW power steering pump you installed? I have seen where when the pump was replaced the Tech replaced the pump he flipped the gear around backwards during the install.
Just an update on my PS problems... I finally figured out that the parts guy sold me the wrong pump. A mechanic told me that there is a right hand and a left hand pump and they look exactly the same. Sure enough, I had put on a right hand and needed a left hand. The problem was, it was on a Sunday when it went out and the only place open was Kenworth. I took the old one down there and they matched it up but obviously he didn't know about the right hand, left hand thing. Anyway, they gave me my money back (they didn't have the left hand one) so I went to freightliner and got the right one. Cost me three days work but I learned something I'll never forget. Hopefully, if someone else has this problem, they might read this post and save themselves some time and trouble.
Thanks for all the help guys.bender Thanks this. -
Crazy situation) my Cascadia look like have bad battery's but I can believe this if I have old batteries but all is new not even 1 month old! So when I try to turn my truck on it's slowly crank than stopped. They said starter is the problem. Well. I change my starter not even a year ago. So the said than wire connections. I went thru all cables and also from starter not start my truck. Than I figured when I crank the high pressure hose to the gear box is super hot! Actually mealting !!! And smoke! The hose !!! So when I move Steerling wheels my truck is turn on right away !!! I'm wtf???? So when I try to start it with out this the hose get huge pressure! Over 3500 psi!!!! The pipe can handle 2800 psi but I know those hose can handle at lost 600 psi more. So I'm not sure is it gear box or oil pump. Anybody have any idea ?
Page 2 of 3
