Power steering tightness
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Highwolf89, Dec 20, 2016.
  1. Highwolf89
    Highwolf89 Light Load Member
    294
    61
    Jul 30, 2013
    I am having problems with my steering i did put new leaf springs and I took out the two inch spacer and bagged the front end of a t600... but feel this problem was before that just getting to me more now... my steering even while empty I feel I am working hard in turning my truck especially backing up... I replaced the gear box relaxed power steering pump and u joints in my steering shaft ... I started to examine my steering column but not sure it is old it is on a 96 but I am worried to spend 1k on something that might not be.... it feels as if there is so much weight on my front axle and I am trying to steering it around..... please help make me want to light my truck on fire lol
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Maybe search box at top right. hard steering. Or no power steering. If you changed the angle of the drag link between the pitman and left spindle arm that might change things. May need a custom link.
  4. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Pulling the blocks out of the front end (between the springs and the beam) changes all the front end geometry.
  5. AModelCat
    164,602
    One thing I would check and see is if your filter in the power steering reservoir is plugged up. They get neglected more than you think. Restricted fluid flow, low power steering assist.
    xsetra Thanks this.
  6. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    This was my problem this summer. Silly me been driving for a "few years".... Didn't even know the power steering system had a filter. I
  7. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    Wait a minute were you having steering issues before you swapped out springs and removed the blocks and installed bags.Those blocks don't just raise the front end they pitch the axle beam
  8. Highwolf89
    294
    61
    Jul 30, 2013
    My steering was tight before the air bags but it seems worse.... over time.... I took those blocks out under the leaf springs that sat on the axle.... hmmm geometry of the pit arm that sounds interesting... I changed the filter
  9. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    I don't believe the pitman arm I know on the old trucks without power steering they used to put a tapered shim between the springs and the blocks to pitch the beam to help steer easier,if you look at the block I think that you will find that it was tapered
  10. AModelCat
    164,602
    All steer axles should have caster (which is set by those tapered shims). Caster is what helps keep you going straight when you let go of the steering wheel. I would get the box and pump checked out. If they are bypassing internally, you'll have hard steering. Also if the input shaft on the box gets buggered up, you might not get full assist in the box.
    lilillill Thanks this.
  11. Highwolf89
    294
    61
    Jul 30, 2013
    My steering is straight when I let go of the steering wheel on truck it goes straight the one mechanic I go to says I am just crazy but I know I am not or feel I am not... I did the gear box and pump just feels as if a crap ton of weight on my steer
