Power Steering
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ColumbiaBoB, Jun 10, 2022.
  1. ColumbiaBoB
    ColumbiaBoB Light Load Member
    188
    21
    May 3, 2011
    Des Moines, IA
    Hi, i have 05 columbia and for the past month or so my power steering has been acting up, I will drive and power steering will become stiff, i have to use both arms to steer and then it will work again, what could it be? Pump? Steering/gear box? Any way to test it? TY
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    Should be all in the search block but a flow - pressure gauge is needed. Make sure nothing is binding in the column and such.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Have you ever changed the filter.
    There is one in the power steering reservoir where the return line enters, usually just under the large cap if the hose is attached to it..
    BoxCarKidd Thanks this.
  5. ColumbiaBoB
    188
    21
    May 3, 2011
    Des Moines, IA
    Not sure if i did, will change over the weekend
