Pre-trip
Discussion in 'Trucking Industry Regulations' started by Everett, Jan 29, 2012.
  1. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    :biggrin_2556: Not sure were too put this, but i'm thinking getting back into trucking when i renew my cdl this nov, i've been studying and stuff on line, getting 100 percent each practice test, seem's i can't find this anywear on pre-trip, but does your hand has too physical touch each part or can you use a mini laser light , like i got for my shop , when i'm working on cars and point out too the auto parts guys and show em what i need when i opean the hood when i get at there store, just wondering.:biggrin_2554:
  3. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
  4. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    When I took the CDL test in NM, we pointed and explained. When I took the CDL test in TX, we didn't even do the pretrip, lol!
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    always start your Pre/Post trips at the same starting location on the vehicle each time.
    Mark
  6. trucknmomx3
    trucknmomx3 Bobtail Member
    5
    Ironwood, MI
    in IL....you need to know critical parts you need to know to check yourself, and must be able to check and show what you are looking for and why.
    first your walk around or walk up to...what are you checking for???
    --- truck leaning to one side or the other, could be flat tire, broken leaf spring, shifted load
    --- visually look to see the lights ALL work (parking,head, etc) nothing broken or missing and no cracks and leaks
    windshield, no cracks, etc....mirrors...same, hork is free and clear of debri....explore remaining obvious visual inspection terms and why info.
    - then open hood, (just a quick run down example for ya is...)
    -looking at the steering column, checking for not bend, cracked or broken...down the arm, steering ring ..knuckle, tie rod ends....to brakes....inspecting for no leaks, broken bent or missing parts...-..continue around front to back of tractor /trailer.....leaf springs, hubs, wheel - looking for no rust if steel wheel or if aluminum white residue that could indicate cracks, or missing or loose bolts........explaining as much info. as possible visually and mechanically as you do each place..-
    ..tanks must have rubber strap under two metal straps prevents metal on metal and securely fastened....use words like....make sure it is SECURE, no missing, broken or cracked.....A LOT.....then tell them why that is.... LOOK toward and you can just point with hand as explaining (either is accepted though..laser or)
  7. Rat
    Rat Road Train Member
    When I took mine here in North Dakota, I just had to point to the parts or syetm I was checking and why I was checking it. Meaning, I did not have to crawl under the truck and show the inspector the slack adjusters, suspension etc. I did not have to drag out my tire gauge to check tires.
    Also, even though I did not bring one, they allow us to use a check list for PTI during testing.
  8. Allow Me.
    10,762
    12,560
    May 28, 2009
    Rancho Mirage, Ca.
    In Ca. just pointing is OK. Used to tell my students, do the "wave" as they're mentioning belts, hoses, pullies etc, as they're "blessing" those items.
  9. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    if it is made of or connected to rubber, (I.E. belts and hoses) remember CDL (not Cracked, Damaged or Leaking) and if it is bolted, its PMS (Properly Mounted and Secured)
    Everett Thanks this.
  10. Everett
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    So it pms rember as a women then :biggrin_25517:
  11. cadillacdude1975
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    lol im not touching that one.
