Pre-trip ???
Discussion in 'Experienced Truckers' Advice' started by O.Henry, Apr 1, 2014.
  1. O.Henry
    O.Henry Road Train Member
    1,224
    2,584
    Sep 1, 2012
    San Antonio,TX.
    How do you check your brake lights?
  3. Chinatown
    Chinatown Road Train Member
    77,557
    183,042
    Aug 28, 2011
    Henderson, NV & Orient
    Look for a reflection off of something; maybe another truck parked behind you or a wall, anything.
    O.Henry and misterG Thank this.
  4. scythe08
    scythe08 Road Train Member
    2,894
    3,799
    Mar 19, 2007
    Portland, Or
    I use a screwdriver that I wedge the pedal with. Thats also how I check the slack adjusters
    rank, O.Henry and Chinatown Thank this.
  5. O.Henry
    1,224
    2,584
    Sep 1, 2012
    San Antonio,TX.
    I have to find a better way than pushing down on the pedal,then running to the back to check,but I just cant get back there fast enough.
  6. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    If someone is behind you, jab the brakes. If they run into you, chances are your brake lights don't work
    falcon241073, pattyj, O.Henry and 7 others Thank this.
  7. O.Henry
    1,224
    2,584
    Sep 1, 2012
    San Antonio,TX.
    Yeah, at least I'll know the brakes work.
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    An officer will tell you. They are nice and will go out of their way to tell you this useful information.
    You can check them at night as you back to a dock or in a parking lot or like scythe said you can wedge something against the pedal. I used my logbook/leather cover worked good.
    O.Henry Thanks this.
  9. PackRatTDI
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    That's one thing the old Ford/Sterling trucks had an advantage on. The brake light circuit was interconnected with the hazard flashers so in those trucks, turning on the hazard flashers also flashed the brake lights on the trailer.
  10. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    i never wanted to run that fast to see if they were on,good idea to check them that is a major violation if they are both out. be safe
  11. Powder Joints
    7,969
    8,354
    Sep 25, 2007
    Rosamond, SoCal
