(Problem) Brake relay valve
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by teemobile707, May 2, 2020.
  1. teemobile707
    teemobile707 Bobtail Member
    47
    30
    May 1, 2020
    Hello,
    Anyone ever have this problem:
    Rear brake relay valve was leaking. Purchased a new one from parts store then installed it. The brand new valve is leaking from the same exact spot of the old one. The pic shows the new valve with the ABS valves connected. I DID NOT replace the ABS valves. They were not leaking.
    Any input would be greatly appreciated.
    Thanks in advance!!!
  3. The_young_buck
    The_young_buck Bobtail Member
    Where was it leaking by? kinked hose at the tip, if there’s any fittings did you use Teflon tape?
  4. AModelCat
    163,855
    Thing you HAVE to remember with air brakes is that the exhaust ports on most valves are open when the valve is not actuated. This means its usually a component downstream that has failed and is backfeeding.
    If the old and new valves are leaking from their exhaust ports, I would highly suspect the interlink o-ring that seperates the air between the service and park sides of the brake chamber has failed.
    If you can, try and pinch off the park lines at the chambers, 1 at a time and see if the leak stops.
    swaan, spsauerland and InTooDeep Thank this.
