Problem with ishift transmission .help plz
Discussion in 'Volvo Forum' started by warrior12345, May 4, 2022.
  1. warrior12345
    warrior12345 Light Load Member
    74
    41
    Jul 16, 2017
    Hi guys
    The fault code i had was p107538.
    Truck is 2015 volvo vnl with ishift.737000 miles.
    .i changed CCA ,CCV, CLUTCH ,flywheel,harness.also shop mentioned that they changed bearing, air fitting, tube,bolt .reset clutch and guess what truck is still hesitating coming out of stop .even in 4th or 6th gear now ..only thing that has not been changed is air hose but mechanic said it is good.am frustrated .am suspecting it is only doing it after driving fr 3-4 hours.
    No transmisdion fault codes.only codes i have are fr nox sensors.
  3. 86scotty
    86scotty Road Train Member
    4,511
    12,219
    Aug 27, 2017
    Appalachia
    Ask this in the Volvo trucks section and you'll get responses from mechanics.
  4. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    What do you mean it's hesitating ?
    Slow shift?
    Or is it an engine power issue?
  5. warrior12345
    74
    41
    Jul 16, 2017
    Slow shift and waits in between gears.
  6. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,265
    Nov 14, 2021
    ALBERTA
    There may be transmissions fault codes that are not showing on the dash.
    A tech tool may catch it during an instrumented test
    (normal driving operation with the tech tool connected to the BUS port).
    Couple hundred dollars in cost, probably for the test.
  7. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Which software shift program calibration are you using?
    You may have one of the lazy shifting calibrations like "comfort" (fuel tanker anti surge calibration) .. swap it to performance or comprehensive and it should improve shift speed.
