Problem With The Low/High Selector
Discussion in 'Schneider' started by terryg247, Oct 3, 2015.
  1. terryg247
    terryg247 Light Load Member
    268
    133
    Feb 1, 2015
    Ontario, Canada
    It seems that every once in a while the selector decides to quit working and even though I have it in low for second gear the truck reacts like it is in seventh and stalls. Now I do not know if I am doing something I am not aware of or it is a mechanical issue with the older Freightliner Columbias.
    I tried to explain this to the garage and got a very odd look and some mumbling about when it comes in for a PM they will look at it.
    Any ideas?
  3. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Splitter could be going out or you could have a leak on one of those little air lines that feed it.
  4. xsetra
    xsetra Road Train Member
    5,190
    7,137
    Aug 21, 2011
    Kind of transmission. Number of gears.
  5. terryg247
    268
    133
    Feb 1, 2015
    Ontario, Canada
  6. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Any audible air leaks? Or just a delay on the split?
  7. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    If its happening when you 1st start out after stopping and its the 1st time your letting out clutch in low range maybe its not getting time in n. before you put in in next gear when changing to low range, just play with your shift before putting in shop?
  8. oragonads
    oragonads Road Train Member
    1,116
    353
    Dec 14, 2011
    The Pacific Northwest
    You should be able to hear the air actuator engage and disengage every time you flip the switch. Just let your air pressure build to full while stopped, shut the engine down and flip your switch over and over again and listen to see if it's always engaging and disengaging or if sometimes it takes a little extra time to work. It most likely be the actuator or the switch/valve. Might be getting old and seizing up.
  9. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
  10. terryg247
    268
    133
    Feb 1, 2015
    Ontario, Canada
    2011. I do not remember hearing any air leaks. The funny thing is it will be fine for a couple of days and then suddenly it does not want to do what it is suppose to. Of course when it does happen it is on some busy street in a major center
  11. Cottonmouth85
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    I'd replace it before it goes out all the way. No fun trying to limp home stuck in 1 range. Been there done that.
    tucker Thanks this.
