problem with truck riding rough
Discussion in 'Kenworth Forum' started by syxxpactrukn, Feb 27, 2015.
  1. syxxpactrukn
    syxxpactrukn Bobtail Member
    5
    Feb 27, 2015
    Henderson,Tn
    i have a 2006 t600....ive changed shocks and put new springs on rear and new leveling valve and it still rides rough,its like its bottoming out...it just hits real hard when i go across a rough spot n the road or railroad tracks does it a little when im bob tailing but more noticeable when i have a trailer on. just need some advice on what else i need to check or even replace?
  3. Scott71
    Scott71 Bobtail Member
    26
    8
    Feb 16, 2015
    Is the leveling valve adjusted properly? maybe too much air in the bags?
    syxxpactrukn Thanks this.
  4. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    Cab shocks and bag? Do you have your load leveled out?
  5. 201
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    Many things can cause a rough ride, although, the truck isn't that old, but you can still check front spring hangers, engine or transmission mounts, cab mounts or where your 5th wheel is. A lot of weight on the steer axle will cause a rough ride. Maybe the trailer. I've had trailers that ride a lot rougher than others. Seat isolator working ok?
    syxxpactrukn and Riprap Thank this.
  6. syxxpactrukn
    5
    Feb 27, 2015
    Henderson,Tn
    ive had it checked and its set right from what they are telling me
    573Rimes1 Thanks this.
  7. syxxpactrukn
    5
    Feb 27, 2015
    Henderson,Tn
    i havent replaced the cab shocks or bags yet, thats my next thing im going to do....as far as the load being leveled out some times it is...but it does it bob tailing too
  8. syxxpactrukn
    5
    Feb 27, 2015
    Henderson,Tn
    im going to take it to my mechanic when i get in and have him check all the spring hangers and all that stuff and the cab shocks and bags too
  9. 201
    12,764
    26,262
    Apr 16, 2014
    Maybe the leveling valve for the cab. I doubt it's the bags or the shocks on the cab, unless 1 is stuck. It would "pogo stick" if the cab shocks were worn.
  10. syxxpactrukn
    5
    Feb 27, 2015
    Henderson,Tn
    when i turn to the right real sharp it jumps up and down real hard and also ive got a lot of popping sound when i turn left or right feels like its bottoming out
  11. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    spring shackels loose
