Problems With Unsafe Loading of Preloaded Trailers
Discussion in 'Experienced Truckers' Advice' started by Captaincrunch670, Mar 25, 2021.
  1. Captaincrunch670
    Captaincrunch670 Bobtail Member
    Mar 25, 2021
    I work for a major carrier which I have been with for 2 years. I take a nightly preloaded trailer. For the past three weeks, I have been required to unload the trailer when I return to my home terminal. Now that I am doing the unloading, I am shocked at how they are distributong the weight.
    I had one trailer with a total of 42,000 Lbs. It has 32,000 on the right side and only about 10K on the left. I am fortunate I didnt have a rollover.
    Another trailer had about 12K loaded in the first 4 feet in the nose. That is a lot of weight to be sitting on the pin.
    Tonight my trailer had 14,700 Lbs in the nose, the first 5 feet.
    I have had three other trailers over the past 3 weeks that were also loaded in an unsafe manner.
    My dispatcher told me "Chicago doesnt have the room on the dock or the time to load your trailer how you want it".
    I told my upper management about the problem a couple of times but things are getting worse.
    What should I do at this point? What can happen if the nose of a trailer is significantly overloaded? Could I lose control? Blow a tire?
    I'm compelled to report them to the DOT.
    tscottme Thanks this.
  3. Eddiec
    Eddiec Road Train Member
    2,318
    3,562
    Feb 2, 2015
    Have you alerted the safety department?
    alds and tscottme Thank this.
  4. Captaincrunch670
    Mar 25, 2021
    I called an ethics/safety hotline. I will have to see where that goes.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Over the pin or over the wheels is the strongest points of a dry van. In between the two is the weakest.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    As long as your not over 34k on the drivers/trailer I wouldn't worry about it. Your rears are rated for 40k most likely. I really wouldn't worry about 1 side being loaded heavy. Just take it easy going around corners
    What type of product is it?
    JoeyJunk and slow.rider Thank this.
  7. 201
    201 Road Train Member
    12,758
    26,250
    Apr 16, 2014
    high plains colorado
    Welcome to trucking, my friend. Poorly loaded trailers is part of the deal, like Forrest Gump, "you never know what you gonna get". I pulled rail cans and nothing was more evident, in that regard, than rail cans. "Oh, big deal, it's just going on the rail", they'd say. Yeah, schmuck, I have to GET it to the rail. Tipped over, overloaded, it was an everyday deal. Once, in my Crystal Farms route days, I come in one morning 2 am, load crew long gone, there's a note, "caution, there's 35,000, (double stacked) return product to Land O' Lakes( Spencer, Wis) in the front half of your trailer", then all my stops after that. The guys at Spencer couldn't believe that, and took pictures, one guy said, "you know you must have been overweight",,I said, "yeah, yeah, just unload the wagon". I think I got an "attaboy" from my boss for making it. I think you should relax, and if you aren't there to observe loading, you're screwed. Don't let these dock schmucks bully you, it's your truck, your name on the bills, you load it my way or I'm leaving. Simple as that, and they will. Like an angry dog that tries to get over on you. In these crazy times, music sure helps me. The late, great Tom Petty,,
    WildTiger1990 Thanks this.
  8. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    What are your weights? As in get a cat scale and if any axle is overweight simply refuse to pull it. Dare them to fire you over it, they will back down if it's that large a company. Even if not, it's a (eventually) paid vacation once you sue and win thanks to the coercion laws built into the regs.
    alds and JoeyJunk Thank this.
  9. Chinatown
    Chinatown Road Train Member
    77,687
    184,118
    Aug 28, 2011
    Henderson, NV & Orient
    I don't see a problem. Maybe you're burned out with that boring routine and should look for another company to work for. Eventually you'll have a bad DAC report over this for complaining to upper management. Everything seemed fine until you had to unload the trailers. Take a vacation and get out of Chicago for awhile and maybe get a new perspective.
  10. EuropeanTrucker
    EuropeanTrucker Medium Load Member
    564
    874
    Jun 15, 2018
    I thought DAC was only used for accidents/violations?
  11. Chinatown
    77,687
    184,118
    Aug 28, 2011
    There's a catch-all "Failure to follow company policy."
    What is a DAC report and what is on it?
    The DAC report provides information on the period of service, equipment operated, loads hauled, driver status and experience, reason for leaving, rehire eligibility, number of accidents with accident detail, drug and alcohol histories including pre-employment test results, and truck driving school performance records.
    JoeyJunk and EuropeanTrucker Thank this.
