Proper gearing
Discussion in 'Ask An Owner Operator' started by Canary379, Jun 17, 2018.
  1. Canary379
    Canary379 Light Load Member
    73
    Apr 13, 2012
    Illinois
    not sure if this should be posted here or in the Garage,but wanted to see what others thought as far as gearing goes.
    Currently I have a 2002 379 Pete with a 550 Cat 6nz engine. Bought used a couple of years ago and absolutely love the truck and the power. We do dump work in the Chicago area mostly out west and not in the city itself. Lots of highway and open roads.
    Anyways, the transmission is an 8 LL and it has 3.90 rear ends running on regular 22.5 rubber not low pros. When I run the highways it will do 60mph at 1500rpm. Ideally I would like to be doing 65-70 and stay under 1500 because with the big motor as we know it really starts sucking down the fuel..
    I am tossing around the idea of maybe changing the rear ends or the transmission to like a 13spd which I really like. Anyone have any thoughts on this or suggestions that they know would bring down those rpms to say around 1300-1400 @ 60-65mph if it's possible. The fuel savings would be much appreciated.
    Thanks Nick
  3. MACK E-6
    49,921
    237,238
    Ours were specced for years to run 1500 at 65 with 10 speeds.
    Oldironfan Thanks this.
  4. wore out
    wore out Numbered Classic
    17,187
    212,216
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Changing to a 13 speed is not gonna change your final ratio. The 8LL is .73 in high gear. The 13 is .73 in high gear as well. They do make a direct 8LL model but with 3.90's and 11R 22.5's you would be tached out at 60mph.
    Really changing the rears is your only option
    370's will drop you about 150 rpm give or take and 3.55's will give you another 150 or so. But with 3.55S your gonna start to notice a loss of that race car feel
  5. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Swap the gear boxes, say a 3:50's to say 3:70 range, or there about. Should get you that speed you desire and keep it in range. They have gearing calculators out there, might want to Google that. The issue is your rear ends, not the transmission.
  6. shogun
    shogun Road Train Member
    6,075
    72,161
    Jan 23, 2009
    Doing a regen
    A good ecm tune from a specialist, some free flowing Donaldson’s like the m1000463 and a power harness would probably get you a nice gain. There are some posts on here about tuning for that motor and who to use, those mufflers are cheap at the TruckPro $100ish, and you can make that harness yourself for a few cents if you can solder decent.
    That muffler was worth a few tenths on its own on a 2007 ISX 475.
  7. Long FLD
    Long FLD Road Train Member
    12,742
    53,223
    Mar 4, 2015
    I’d probably just put some tall 24.5’s on the drives.
    AModelCat, x1Heavy, BigBob410 and 6 others Thank this.
  8. Ruthless
    Ruthless Road Train Member
    9,134
    90,646
    Aug 28, 2010
    The City.
    ^^ x2
    AModelCat, x1Heavy, BigBob410 and 4 others Thank this.
  9. TripleSix
    133,047
    Nice numbers on that truck, BTW. The only thing that's eating you is the highway cruising, right? Well, except for the taller rubber, there's no easy fix. The best fix would be a 2 or 2 speed auxilliary on the back of your transmission, but that's $$$$$. It works like the transfer case on a 4x4 pickup.
  10. Long FLD
    12,742
    53,223
    Mar 4, 2015
    3.90’s and tall 24.5’s.
    x1Heavy, Oxbow, Ruthless and 2 others Thank this.
  11. Largecar359
    Largecar359 Road Train Member
    1,075
    1,324
    Aug 13, 2011
    New Jersey
    I like the little display that says 7.0mpg.
    I think that’s what the dude is looking for, 65mph with 1500 at the tach.
