Prostar tailights
Discussion in 'International Forum' started by My11Inter, Feb 17, 2016.
  1. My11Inter
    My11Inter Bobtail Member
    41
    May 19, 2015
    My prostar tailights don't turn on. They only blink and stop, but don't work as marker lights. All other lights work great. Thanks!
  3. Heavyd
    Heavyd Road Train Member
    7,824
    6,273
    Feb 4, 2009
    Have only your park lights on, disconnect the connector at the tail light and check for power at the plug, should have power on one pin.
    My11Inter Thanks this.
  4. My11Inter
    41
    May 19, 2015
    Thanks!
  5. My11Inter
    41
    May 19, 2015
    Lights are still not working properly. Sometimes there both on, and sometimes one is very dimmed and the other one is completely off. Or one is on normally and the other off or dimmed.
  6. Heavyd
    7,824
    6,273
    Feb 4, 2009
    Check all your tail light connectors for corrosion.
  7. My11Inter
    41
    May 19, 2015
    They don't seem to be corroded, but I'll clean them and grease em.
  8. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    753
    Nov 18, 2013
    Tustoned Arizona
  9. banders77
    banders77 Light Load Member
    135
    189
    Feb 27, 2015
    San Antonio, TX
    pull the panel off the passenger side and check fuses/breakers. use a plastic seal and slide it in the trailer plug
  10. Heavyd
    7,824
    6,273
    Feb 4, 2009
    Is it just the actual tail light bulb itself, or do have problems with turn/stop light too?
  11. My11Inter
    41
    May 19, 2015
    Yes, tailight itself is the problem. They don't turn on with park lights. Turn signals and stop works perfect. There LED lights if it matters.
