PTO pump issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DLament, Jun 10, 2025.
  1. DLament
    DLament Bobtail Member
    41
    25
    Mar 12, 2022
    Believe its a permco pump not sure on the pto but both are only a year old, never been ran more than the time it takes to raise the bucket up. I had a surgery done and the truck has been sitting for about 2 months, I just had it running to make sure everything is still moving good and I can't get any pressure. Pump engages and disengages normal, sounds normal but just don't have any pressure. I tried engaging and disengaging multiple times and about every 3rd time I can get it to move very slow if I idle the engine up but thats it. Seems like its got air in the system? Never had this issue before and its not the first time the tuck has sat for a month or so, just hoping the pump didn't crap out. Also the trailer is only a year old, cylinder is completely dry.
  3. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    Did you check your oil level? Sounds like you're out of hydraulic oil
    Big Road Skateboard Thanks this.
  4. DLament
    41
    25
    Mar 12, 2022
    I did check that as well thinking maybe somehow a line got loose and leaked out but I've got 40 gallon or more in the tank
  5. Deere hunter
    2,118
    10,004
    Aug 5, 2017
    Shallowater Texas
    Well the only other thing I can think of is your pressure valve is bypassing.
    Star Rider Thanks this.
  6. AModelCat
    164,436
    This is where you gotta break out gauges and a flowmeter. Start testing components.
  7. Joyce's Volvo
    Joyce's Volvo Light Load Member
    116
    153
    Jun 28, 2016
    I agree with deer hunter, more than likely the PRV has something in the seat or spring is broken. Does it have a suction filter or screen on the supply line, either one could be blocked. Should have a valve on the supply line it could be partially closed.
    Deere hunter and Star Rider Thank this.
  8. Star Rider
    Star Rider Road Train Member
    1,784
    18,394
    Sep 23, 2019
    Also check that the suction line isn't collapsing and blocking flow to the the pump.
    Deere hunter Thanks this.
