What can I expect for orientation? How long is for exp driver. We are gonna go try there team position and hope it's what they say it is.
Pumpkin orientation ?
Discussion in 'Schneider' started by jtaran06, Jun 1, 2014.
There are lots of threads already addressing this subject...
From what I've read, it's 3 days for experienced drivers. I can't tell you what to expect, though. -
Dot physical, blood pressure check, pre-screen work out, including lifting pulling, climbing, crouching, in between each one they check heart rate. Lots of talking, computer work, road test, pre, post, backing.Driver Orientation Process: http://youtu.be/lAY-V7p2Aeo
jtaran06 Thanks this. -
If you aren't in good physical shape Id skip it. Their physical requirements are stupid bad. Its their way of weeding out the wide loads.
Took the physical today I thought it would be hard as I'm small, but not that bad. Just had hard time on one test and the tester said just a little more she did not let me fail.
