Purchasing a 2000 W900
Discussion in 'Kenworth Forum' started by haymanw900, Dec 12, 2016.
  1. haymanw900
    haymanw900 Bobtail Member
    I am currently looking at a 2000 W900 with a 3406E Cat and a 13 spd Eaton Fuller. 356K miles on the whole truck. They are asking 30K, is this a fair price to start haggling? The interior needs some work but the exterior is in good to excellent shape. I was wondering what kind of things to look for as far as problems? How in depth do I need to go besides checking for fluid leaks? Is this year and model notorious for any major issues? This is my first truck purchase so any help would be great. Thanks!
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    We had one truck about that year that an aircraft carrier had a tighter turning radius. You would also swear the fan clutch was coming apart when it kicked in.
    wore out and haymanw900 Thank this.
  4. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    I doubt the 356k on an almost 17 year old truck is original, more like 1.3+ million miles.
    I would ask for Service Records and do a www.rigdig.com report.
  5. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
  6. haymanw900
    I know the 356K miles are on a rebuilt engine. I'm sure the transmission/rear end has never been touched. I really like the W9s and could deal with the turning radius. Ill just have to learn how to drive an aircraft carrier haha. What about clutch issues? How long do they generally last?
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    I've got a '99 W9 (mine has a Cummins). Shows 3xx,xxx but I know it's 1.3 million. Like was mentioned, it turns like a battleship, and I haul frac sand with it. Have to back into some VERY tight quarters sometimes. I've learned to get it done, but the fleet of Volvos I run with can get it done a lot quicker. Other than that, it's a great truck.
    haymanw900 Thanks this.
  8. boneebone
    2,297
    2,372
    Mar 13, 2009
    I replaced my Clutch on a 13 Speed at 400k miles back in 2005, (not because the Clutch was bad), but my Transmission Mounts were worn out and replaced, and the Transmission had to be pulled out, so I decided to kill two birds with one stone and replace the Clutch anyways.
    I now I have 925k on the same Clutch.
    I replaced the Clutch Brake about 100k miles ago, but same Clutch.
    Clutches can last a long time, not indefinitely, but I float gears, don't ride the Clutch and keep the Clutch Brake adjusted.
    In your situation, without knowing the history of the Transmission, I would keep the Clutch adjusted, fittings greased and put money aside for a eventual Clutch Job in the future.
  9. wore out
    wore out Numbered Classic
    17,168
    211,848
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Quicker but not cooler. Just saying
    Bean Jr., ShooterK2 and IH Truck Guy Thank this.
  10. Dirty-Low-Walker
    Dirty-Low-Walker Medium Load Member
    359
    543
    Dec 17, 2013
    Sometimes you can come across a truck with those miles.
    Last year i found a 2000 KW W900L with just over 400K miles, original owner, had all his documentation showing his jobs with miles, original ECM that also documented the mileage, i didn't buy it because it had a sleeper.
    This fall i purchased a 1999 T800B which had the original build sheet that has 54K original miles, i was skeptical of the mileage and had 2 different mechanics check the truck before i purchased it.
