Push in the clutch method when skiding
Discussion in 'Experienced Truckers' Advice' started by carsonallen1977, Sep 4, 2012.
  1. carsonallen1977
    carsonallen1977 Bobtail Member
    35
    5
    Aug 27, 2012
    I've read allot of articles online about winter driving as well as talked to a few instructors. They say if you skid, tractor or trailor, to push your clutch in and steer to whare you want to come out of the skid. I have also heard that if you don't match rpms disingadging the clutch you can start another skid.
    What say You?
    Thanks
  3. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,442
    Jun 9, 2010
    Home
    Let the winter games begin!!!:biggrin_2552:, all kidding aside, sounds right to me, But?, I've never been in a skid, so I'm just guessing
  4. Moosetek13
    Moosetek13 Road Train Member
    14,978
    19,021
    Nov 1, 2010
    Burnsville, MN
    How do you 'match RPM's' while disengaging the clutch?
    As soon as you push the clutch pedal your drivetrain is running free and you are coasting.
    My first thought when first skidding is to turn into the skid (as in, steer to where your back end is swinging - which will also be the direction that you want to be going) and apply just a very little power to help pull out of it.
    That's how I do it in a 4-wheelie anyway.
    I have yet to be in the situation in a big rig, but I think it should be about the same - while also watching what the trailer is doing, and compensating for that.
    Talk about a juggling act.
    carsonallen1977 Thanks this.
  5. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    If your tractor breaks traction and the drive wheels start to spin, causing the drive wheels to want to go sideways on you, your first response should be to push the clutch in then shift to neutral, QUICKLY, at the exact same time you should be turning the steer wheels parallel with the road. When you do this it will cause the drive wheels to slow down to the same speed as the passing pavement and it will straighten right out for you. I have never had a trailer come around on me for no given reason. I have had a trailer want to slide off the road while running on ice because the road surface was not level, and the trailer followed the gravity, this has happened to me many times, but every time I was going walking speed or less because of the ice, in which case it was easy to roll to a complete stop, or close enough that I could continue rolling. If you are going in a straight direction, the trailer can't come around on you without a given input, usually you will know what that input is at the time and quickly correct it. I have tried just pushing the clutch in only, but at the moment it seems like there is still a drag on the driveline, so I always go for neutral. Remember during this emergency, you have got to keep driving the truck, so keep your steer wheels pointed in the direction that you want to go, (Parallel with the road). It is just like you would do if you are in a large parking lot in the winter time goofing around in your car, they call that following up with your steering, go to the mall parking lot and practice with your car in the winter, these movements should become automatic to you, there is little time for thought. Just remember to keep driving the truck.
  6. BigJim1937
    BigJim1937 Medium Load Member
    303
    135
    Mar 27, 2012
    Fargo,ND
    A Jackknife situation is a trailer skid, now I know, what to do the get out of a jackknife has been explain to you on another thread. The difference with a truck skid is you dont want to add power hence push in the clutch. Matching your rpm is not for when disengaging but when you engage, you just work your way out of a skid, not matching your rpm when reengaging will cause you to go into another skid situation.
  7. Ezrider_48501
    3,845
    5,134
    Apr 2, 2011
    bismarck, nd
    the best thing to do is to know what is causing the skid in the first place then you will know what to do to correct it, if your powering up a hill and your drives start skidding let off the throttle, if your jake beaking down a hill and your drives start skidding turn off your jake, if your hitting the break and your trailer starts skidding let off the break ect. pretty basic explination but the most important thing is to keep a feel for your rig and be alert and pay attention to the way your rig is handling and how the truck reacts to your input, and most importantly do everything in a smooth and controlled manner
    CAXPT, gb2nyc and carsonallen1977 Thank this.
  8. carsonallen1977
    35
    5
    Aug 27, 2012
    Some of the best advice i have had so far!!!
  9. BigJim1937
    303
    135
    Mar 27, 2012
    Fargo,ND
    A lot of the advice given in these threads are good, you need to read through and find the parts that apply to you exact situation, questions can be very general, some people give more direct answers than others all in all however if it doesnt help you with your exact situation something you read here may help in another situation you may find yourself in later.
  10. carsonallen1977
    35
    5
    Aug 27, 2012
  11. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    only been in a skid once. had the jakes on going downhill from idaho to montana. turned off jakes and light brakes to keep from hitting the jersey barricades. luckily it was a small patch of ice. but i was going slow anyways. had a few trucks pile up behind me. once out of the construction zone. they all went zooming past me and we was only half way down the hill.
