Pusher axle issue....
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Markpaul365, Mar 30, 2024.
  1. Markpaul365
    Markpaul365 Bobtail Member
    7
    Hey all,
    I have the following issue with a W&C Pusher axle.
    While actuating the push axle down from the cab the axle doesn't fully contact the ground. While performing my inspection of the airbags I noticed that the front "axle up" airbags do not deflate while the rear "axle down" inflate. So it seems like I have a tie-up with the airbags, air system seems to be up to spec, with no obvious damaged components or air leaks. Please help!
  3. lester
    2,956
    8,076
    Jan 2, 2012
    NW, Iowa
    the plumbing is either wrong or your valve is bad
    Deere hunter Thanks this.
  4. Markpaul365
    7
    Thanks for the reply. No previous repairs, there are about 5 valves within the system. Not sure where to start. Trying to find some sort of service information is next to impossible. Thank you your help.
  5. IH Truck Guy
    4,885
    56,661
    Mar 2, 2008
    Purgatory
    New truck?
    I have a Brand new freightliner with a factory lift axle was all run thru the computer.
    Had to let the dealer hook it up to their computer to diagnose.
  6. lester
    2,956
    8,076
    Jan 2, 2012
    NW, Iowa
    yes what is this on?
    Lift axle is pretty simple, there is a valve that one way puts pressure to your down bags and releases pressure from your lift bags. then when switched does the opposite. there is probably a pressure regulator for down pressure that you can adjust and I'd guess there are quick release valves on the down and lift bags. the quick release valve just helps it move faster, I don't think they are necessary.
    So start following air lines and see where everything goes. find your lift valve.
  7. JB7
    JB7 Road Train Member
    1,001
    1,770
    Dec 13, 2022
    Laurel, MD
    W&C - W&C Suspensions - Heavy Duty Truck & Trailer Suspensions & Axles (wcsuspensions-intl.com)
    If you go to Tech Lit and then Air Control Kits there are schematics of the systems they make.
    Need Help? Call 1-972.838.1266 or Email Contact Us
    You could also contact them for service info but they may try to send you to an authorized service center.
  8. idriveaholden
    idriveaholden Super Heavy Hauler
    708
    2,233
    Mar 14, 2018
    yeah probably a manual regulator to control the pressure you're not seeing
    if its auto regulating, good luck with that
