Question about split sleeper berth
Discussion in 'Questions From New Drivers' started by Mtloaf, Dec 31, 2020.
  1. Mtloaf
    Mtloaf Bobtail Member
    10
    May 4, 2020
    Assuming this is my second day working (first day I worked until 10pm).. I start the new day at 8am.. I then go on duty for 10 mins- then start driving.. At 1pm (5 hours later) can I then take a 1 1/2 break.. then work until 9PM... at this point could I take a 8.5 hour break...(combine with the 1.5 break earlier to equal the 10 hour break.) So I can start at 5:30 am??
    Or instead of taking the 10 hour break.. I take 8.5 hours to start my second day.... so I start at 6:30 am... I then work for 5.5 hours.. I then take my 1.5 hour break... I can work another 8.5 hours???
  3. Farmtractor9900
    Farmtractor9900 Light Load Member
    162
    433
    Nov 6, 2020
    FMCSA
    Sleeper Berth Provision
    Drivers may split their required 10-hour off-duty period, as long as one off-duty period (whether in or out of the sleeper berth) is at least 2 hours long and the other involves at least 7 consecutive hours spent in the sleeper berth. All sleeper berth pairings MUST add up to at least 10 hours. When used together, neither time period counts against the maximum 14- hour driving window.
    SoulScream84 Thanks this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Nope. The minimum off duty time is 2 hours. The sleeper berth time can be 8.5 hours though, just has to be a minimum of 8 in the berth.
    gentleroger Thanks this.
  5. SoulScream84
    3,430
    26,372
    Mar 21, 2020
    They're allowing 3/7 with the new provisions.
    Farmtractor9900 Thanks this.
  6. kemosabi49
    10,944
    47,643
    Jan 13, 2013
    SW Arkansas
    Still has to be a 2 hr minimum. 8.5hr break in sleeper with a 1.5hr break won't do it.
    Cattleman84, gentleroger and ZVar Thank this.
  7. SoulScream84
    3,430
    26,372
    Mar 21, 2020
    I'm aware. Just stating the 8 is no longer the minimum sleeper portion, as long as your other break is 3 hours. Also both brakes when doing the split now pause your 14, where it used to only be the sleeper portion which did so.
  8. ZVar
    10,911
    23,832
    Sep 10, 2010
    Flint, MI
    Yes, and if the first portion is 2 hours, the second portion has to be a minimum of 8 in the berth.
    The op asked about if taking a 1.5 hour break was enough. 2 is the closest so that leaves 8 as a minimum.
  9. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    Also of interest. I've found the new split provisions give me much more flexibility with load appointment schedules. Being able to pause the 14 hour clock by taking at least 2 hours of off duty, but not HAVING to take a full 10 hours makes it much easier to get to appointments.
    If you do extend your 14 hour clock by taking an off duty break of at least 2 hours, but instead of later just taking the 7 or 8 hours of sleeper berth and getting back on duty, you take a full 10 hour break, be advised you still have to show the 7 or 8 hour in Sleeper Berth, even though it is a part of your 10.
    Seems to me if you take a full 10, the sleeper berth requirement is a mute point. But, I did this once and our safety folks fussed at me about it saying it was an HOS violation.
    Now then, unsure if that is just my company's interpretation of the rule, or if FMCSA also thinks it is that way.
