Question about truck load
Discussion in 'Experienced Truckers' Advice' started by jennsunshine, Jul 5, 2018.
  1. jennsunshine
    jennsunshine Bobtail Member
    8
    6
    Jul 4, 2018
    Hello again,
    I got great advice here about driving the Western mountain passes in a 26 foot Penske International one-way.
    Now, I have another related question.
    I mentioned before that Penske gave us a crappy truck when we left Massachusetts. We barely made it up the hills in the Poconos. Took it to their service center in Binghamton, where it was gone over by multiple mechanics, who couldn’t figure out the problem. We got subbed out into a new truck.
    We packed the truck very carefully before we left Mass., with the heavier stuff toward the front...lots of art and paintings (late mother was an artist). Everything strapped in. Lots of boxes, and not much furniture.
    Penske hired movers to unload and reload into the new truck. My husband gave very specific instructions about re-loading. They didn’t follow them. Everything that was at the back of the truck is now at the beginning (they backed the trucks together). This means the art is at the back.
    Also, to be clear, we aren’t carrying any heavy appliances. For furniture, we have a couch, a couple of single mattresses, a couple of dressers, tables, a dining hutch, sideboard, and other odds and ends of furniture. Primarily, the heaviest items are all of the boxes we are bringing with us.
    The load appears to be packed very tightly, and was strapped carefully from what we could tell. When I drove it from Binghamton to our friend’s (38 miles), the truck felt like it was riding better.
    My husband is very concerned that the load will shift significantly, or the art will be damaged/ruined. Do you think the load should be repacked again (impossible with just the two of us), or will be OK as it is?
    Yes, this has been a bit of a nightmare. Movers also packed our camping equipment where it is unreachable, and that was what we were going to do along the route. We are on an extremely tight budget and lodging was not part of the plan.
    Anyhow, advice and suggestions greatly appreciated! By the way, if you see a 26 foot Penske towing a tiny pink/fuschia colored car on the way west, give us a smile and thumbs-up. We need all the encouragement we can get!
    Jenn
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    It will never be loaded as well by someone who does not have a vested interest in the product as it was by the first person who loaded it.
    hopefully you got some experienced movers and not just a couple of temps from a local temp agency, but you never know. Someone should have supervised the entire process, meaning you or your husband and not someone from Penske.
    jennsunshine and Feedman Thank this.
  4. jon69
    jon69 Medium Load Member
    525
    506
    Jun 19, 2018
    Loading doesnt matter much. Get the stuff in there and shut the door.
    What matters is driving gently. Go 5-10 MPH below the posted speed limit. Avoid bumps, sudden stops and starts as well as go around curves gently.
    Also stop at a CAT scale and weigh the truck. Make sure you are not over 13 tons. If you are, even by 50 pounds it puts you in a whole other classification as far as legality.
    69
    jennsunshine Thanks this.
  5. homeskillet
    homeskillet Road Train Member
    6,316
    48,880
    Jun 1, 2013
    Dayton, OH
    I offer encouragement......
    I have done the DIY moves many many times. Moving sucks.
    If it were me, and the load was well secured and the truck was riding well, I'd just leave it be. You could cause more damage trying to "save" the artwork.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Most important to make sure that nothing can move causing rubbing and abrasions. If everything is tight, you should be good to go.
    Cardboard works wonders.
  7. Ridgeline
    22,723
    123,025
    I would not worry about it unless it was just thrown in with no straps.
    However two things of advice, always always supervise any thing like this, tell them up front you want it packed just like it is and if you see something wrong, stop them and get it fixed, you are the boss.
    Second is dealing with "art work" of any sort, always crate it.
  8. jennsunshine
    8
    6
    Jul 4, 2018
    Oh, we were there supervising all right. Problem is, they had the trucks backed up to each other, so we couldn’t see what they were doing. They didn’t listen to us at all, and claimed they were experienced professionals. In reality, they looked like Day laborers.
    We squawked at Penske today, and they are hiring a different moving crew to totally unload and reload the truck the right way this time.
    Penske knows they have a lot on the line, and this shouldn’t have happened in the first place.
    We’re going to get this done.
    Bakerman Thanks this.
  9. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    Ok here is the story, penske hired the lumpers to van to van your load. Even if you were there trying to supervise. Your load was NOT going to be loaded the way you wanted. The way yp u wanted it would require the first truck to be unloaded from truck onto the ground. Then reloaded from the ground onto the 2nd truck. Since (and yes this is a dig) decided to not hire professional movers to move you. Or at a minimum hire pro movers to do the loading. The most you can hope for is that when the lumpers van to vaned. They loaded tight and put heavy on the bottom, chunk in the middle, and lampshade light at top. I can almost guarantee if you unload and reload again at this point. You are just going to create damage, along with a lot of unnecessary work. Chances are your worrying about nothing
  10. jennsunshine
    8
    6
    Jul 4, 2018
    Just a quick response - Penske hired the movers, not us. The first time around, we did have professionals, especially for the art. We loaded the first time based on specific guidance and instructions we were given. The ‘lumpers’ didn’t give a flying fig, and made it almost impossible to supervise.
  11. jennsunshine
    8
    6
    Jul 4, 2018
    Oh, this sucks big time. This cross-country saga is after 3 years of taking care of elderly parents, closing down the house they lived in for 50 years, and selling it in a short sale. Mom died, and Dad has Alzheimer’s and lives with brother in Seattle. The art is my mother’s; she was a professional, who painted for over 50 years. Lots of art is what she left behind. We are doing the best we can with this on a mega shoestring budget. We lost our shirts being caregivers, and we are starting over in the PNW.
    Oh, and after driving this rig and towing the car this far, I just want to say we both have a new understanding and enormous appreciation for the challenges that long haul truckers face. It’s a ginormous job to get cargo from place to place, intact and undamaged, while keeping yourself and fellow travelers safe on the road.
    Thank you.
