Question regarding Reefers
Discussion in 'Questions From New Drivers' started by Toms_2003_GT, Sep 20, 2010.
  1. Toms_2003_GT
    Toms_2003_GT Light Load Member
    72
    21
    Jun 15, 2010
    Soddy Daisy, TN
    While we were fueling up Friday there was a Central Refrig. truck parked next to our group. Ive seen some reefer vans with a secondary (albeit small) fuel tank under the trailer but this one did not have it. Can the driver control the amount of fuel the freezer unit gets or is it automatically controlled???
  3. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    It didn't have it or you just couldn't see it?
    Did it have CA skirts on it? Possibly hiding it?
  4. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    All reefer trailers have their own fuel supply. A tank separate from the tractor. There are several reasons for this: First, if you're a lease operator or O/O and it's drawing fuel for your fuel tank, how do you get reimbursed?
    Reefer fuel is not subject to road tax. When you fuel up, the CRT display will ask you TRACTOR, REEFER, BOTH. Then you fuel your tractor, hang up the hose, pull forward and fill the reefer. It transacts two different transactions. You then apply to the proper authority to get a credit for the tax on that fuel purchase. (this is a credit against all the road tax you're sending each state anyway)
    Lastly, it's not uncommon for reefer trailers to be left at a shipper where they will load it, set the temp, then stage it in their yard for you to come pick up. It has to have it's own fuel supply to do this.
    In answer to your last question, no...the driver does not control the fuel flow to the engine running the compressor. This is all controled by the settings for the unit on the control panel. Temperature, contineous run or cycle run, etc.
    As a driver, you simply keep the tank filled, set and monitor the unit according to your customer's requirements on the BOL.
    StruckANerve Thanks this.
  5. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    But make sure you turn it off before fueling it...otherwise you may spend some serious time re-priming the reefer engine. Learned that one the hard way.:biggrin_25511:
  6. Allow Me.
    10,761
    12,552
    May 28, 2009
    Rancho Mirage, Ca.
    If you didn't see a fuel tank under the trailer towards the front, he probably had a dry van. Years ago, I worked for Sam Tanksley Trucking, a refrigerated carrier, BUT, he had 2 trailers(dry Van) for an account hauling formica. Not sure about Cent Ref.
  7. Toms_2003_GT
    72
    21
    Jun 15, 2010
    Soddy Daisy, TN
