Questions about returning to Work.
Discussion in 'Trucking Industry Regulations' started by withit, Sep 13, 2013.
  1. withit
    withit Light Load Member
    86
    41
    Jun 12, 2010
    SW MI
    Back at the end of January while working i took a bad fall an blew my right ankle out the side of my leg (Compound Fracture). I have been on workers comp since. Now im healed enough that i think i can return to work the problem is that i have to wear a ankle brace an my doctor has me taking Vicodin. I want to know can i go back to work with the brace an taking my meds our do i have to wait longer till i nolonger have to take pain meds?
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,382
    Jul 16, 2012
    Bentonville Arkansas
    I think Vicodin will stop you. My company told me any type pain killer we can't drive.
  4. brsims
    brsims Road Train Member
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    I'm pretty sure Vicodin is one of the no-no medications for driving. Isn't one of the possible side effects drowsiness?
  5. withit
    86
    41
    Jun 12, 2010
    SW MI
    I have been searching the FMCSA website an i cant seem to find anything that specifically says no to Vicodin/Hydrocodone. So i figured i would ask here. If you say that FMCSA says no can you please cite the reg number cause i just cant find it. I just want to make sure that if i go back to work but am still taking my meds that im not going to be in deep #### is all.
  6. LoboSolo
    LoboSolo Heavy Load Member
    737
    4,267
    Jun 21, 2013
    Highway 20
    Vicodin contains a combination of acetaminophen and hydrocodone. Hydrocodone is in a group of drugs called opioid pain relievers. An opioid is sometimes called a narcotic.
    Hydrocodone is a Schedule II substance according to this:
    21 CFR § 1308.12 Schedule II.
    (a) Schedule II shall consist of the
    drugs and other substances, by whatever
    official name, common or usual
    name, chemical name, or brand name
    designated, listed in this section. Each
    drug or substance has been assigned
    the Controlled Substances Code Number
    set forth opposite it.
    (b) Substances, vegetable origin or
    chemical synthesis. Unless specifically
    excepted or unless listed in another
    schedule, any of the following substances
    whether produced directly or
    indirectly by extraction from substances
    of vegetable origin, or independently
    by means of chemical synthesis,
    or by a combination of extraction
    and chemical synthesis:
    (1) Opium and opiate, and any salt,
    compound, derivative, or preparation
    of opium or opiate excluding
    apomorphine, thebaine-derived
    butorphanol, dextrorphan, nalbuphine,
    nalmefene, naloxone, and naltrexone,
    and their respective salts, but including
    the following:
    (i) Codeine ..................................................................... 9050
    (ii) Dihydroetorphine ...................................................... 9334
    (iii) Ethylmorphine .......................................................... 9190
    (iv) Etorphine hydrochloride ........................................... 9059
    (v) Granulated opium ..................................................... 9640
    (vi) Hydrocodone ........................................................... 9193
    (vii) Hydromorphone ...................................................... 9150
    Under FMSCA regulations, it says this (I put highlights in bold ):
    Subpart B - Prohibitions
    FMSCA § 382.213
    Controlled substances use.(a) No driver shall report for duty or remain on duty requiring the performance of safety sensitive functions when the driver uses any drug or substance identified in 21 CFR 1308.11 Schedule I.
    (b) No driver shall report for duty or remain on duty requiring the performance of safety-sensitive functions when the driver uses any non-Schedule I drug or substance that is identified in the other Schedules in 21 CFR part 1308 except when the use is pursuant to the instructions of a licensed medical practitioner, as defined in §382.107, who is familiar with the driver's medical history and has advised the driver that the substance will not adversely affect the driver's ability to safely operate a commercial motor vehicle.
    (c) No employer having actual knowledge that a driver has used a controlled substance shall permit the driver to perform or continue to perform a safety-sensitive function.
    (d) An employer may require a driver to inform the employer of any therapeutic drug use.
  7. brsims
    5,296
    6,522
    Aug 8, 2009
    Meadville, PA
    And let's not forget company policies involving various medications...those can also throw a spanner in the works for prospective new employees.....
    Lilbit Thanks this.
  8. withit
    86
    41
    Jun 12, 2010
    SW MI
    Thank you for your help.
