Quick question on Housing
Discussion in 'Ask An Owner Operator' started by Thotphobia, May 17, 2022.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Can y’all experienced drivers explain to me the housings on the axles ? Why are some bigger than others? Does the bigger the housing the higher the gear ratio or that doesn’t matter?
  3. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    I don't think it's about the gear ratio it's about the actual heaviness of the rears themselves.
    So for example if you had 46000 lb Rears the housings would be heavier than 40,000 lb Rears.
    Don't forget the heavier duty the rears are, the larger the components are inside of them, like the axles bearings Etc
  4. AModelCat
    164,178
    Bigger housing = higher rating.
  5. Thotphobia
    69
    47
    Apr 21, 2021
    What you mean rating
  6. AModelCat
    164,178
    More weight it can handle. Likely more torque too.
    Put a 40k rear next to a 46k rear and its a way beefier housing, bigger bearings, bigger hubs etc.
  7. Thotphobia
    69
    47
    Apr 21, 2021
    Ahh okay so I does not have to do anything with the gear ratio? I thought the bigger the housing the higher the ratio, the Pete we bought has 46k rears, the housing looks big compared to my other Pete.
  8. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,939
    Apr 2, 2021
    TARHEEL
    Peter Bilt It Better!!
    as well
    Ken Is Worth It too!!
  9. AModelCat
    164,178
    You can stick just about any ratio into any housing. I had a set of 44k Rockwells with 5.29 rears in it.
  10. Thotphobia
    69
    47
    Apr 21, 2021
    10 4, you see my dad thinks the bigger the housing the higher the ratio. Cause most of the Volvo’s have a super small housing that’s why he thinks they have small gear ratio, but I told him that the truck we bought has a big housing but that don’t matter it can still have 3.70s.
