Quik stops
Discussion in 'Trucking Industry Regulations' started by KAMAZ, Oct 9, 2006.
  1. KAMAZ
    KAMAZ Bobtail Member
    47
    Oct 4, 2006
    St. Petersburg, Russia
    By law, am I required to write in log book every stop I make? When I stop for a few minutes at rest area I don't write it in my log book. I did before, but I stopped doing that because I think it is a waste of time. The stop is less then 15 minutes, is there a point in writing it?
    And another question...
    Sitting next to a co-driver is on duty or off? For example, if I sleep for 10 hours and sit in the truck looking out the window for 1 hour while my co-driver is driving. Is that on or off duty?
  3. TurboTrucker
    TurboTrucker Road Train Member
    861
    276
    Feb 23, 2005
    Rossville, Georgia
    To be "perfectly legal", you are supposed to draw a line down, or "flag it", and record the nearest town and state, but I think that most people who take a quick duck into a rest area, and are back on the road in a matter of a few minutes, don't bother with it. It would tend to clutter up the remark's section if you did this, and you have an overactive bladder or something, so I don't see any need to sweat that small of a break.
    I'm doing this from memory, because the FMCSA site is down at the moment, but unless I am sadly mistaken, under that scenario, it is considered, on-duty, non-driving almost universally, according the the guidance section of the rules.
  4. earthbrown
    earthbrown Medium Load Member
    362
    40
    May 27, 2006
    I use quick stops to help hours sometimes,
    Say i dive into the rest area at 0635, leave at 0645, I gain 5 minutes of driving, if I record this as sleeper or off duty.
    Can also use this to preserve hours on a day you dont have to run hard, shaving off 5 min 3 times saves you 15min of duty time for a later day....
    Also whjen leaving truckstops if I leave at 0553 it is legal to say you left at 0600 as it is within 7min and closer to 0600 than 0545, and can save your log a little when it takes 5 min to get from truckstop to the freeway.
    K
  5. Eight433
    Eight433 Light Load Member
    100
    23
    Aug 12, 2006
    anything that can be completed in less than 7.5 minutes does not legally have to be mentioned on a log. but as mentioned, sometimes its worth it to help keep your hours a little lower.
  6. KAMAZ
    47
    Oct 4, 2006
    Yes I did that too, at the beggining of my american driving career. But then I realized that you loose more time then gain. You loose time stopping/braking, pulling into the rest area, then pulling out, speeding up to the speed limit. It all takes time. So it is better to make as little stops as possible. Try to go the whole 10/11 hours at the same speed. You do more miles that way. Ofcourse that is very hard to do, but I try to only make 1 or 2 quick stops. If I ever worked by myself, maybe I would strech my driving time by making stops. But we drive a team, so there is no point in wasting time.
  7. BUBBABONE
    BUBBABONE Light Load Member
    83
    11
    Oct 30, 2005
    SOUTH CAROLINA
    Look at it this way....If you stop for a restroom break and spend 6 minutes in the rest area and you do this say 3 times a day that is eighteen minutes but if you log it as 15 per stop that is 45 minutes...45 min = about 40 miles....40 miles times your mileage rate...just how much are those breaks costing you.
  8. buck and a half
    buck and a half Mr. Miles & Miles with Many Smiles
    775
    57
    Aug 11, 2006
    madison,me
    If you are in ny or me or pa,nh, the dot are watching alot in these states and rest areas also va.,if they time you or watch you and check you,if you flaggeg and it was 15 mins or more they will write you a violation,between 80 and 100. i believe. I haven't been caught,like I said in another post log that 15 minsor flag if less,I put it down as a safety ck, I aways take a minute to kick the tires. I have been told by dot when you do this little bit,it looks good to them and helps you in the long run. like earth brown said,it also helps your driving time. If you get caught driving over 11 or 70 you can pay up to 1000. fine. All it takes is an accident and your screwed and caught dead wrong.
  9. Burky
    Burky Road Train Member
    I don't log any short breaks when I stop at a rest area, or pop into the mini mart for a soda or some chips. The stops are usually short enough that they aren;t worth logging. My other reason for doing so is that the time slowing down, actually stopped, and getting back up to speed lowers my average speed. So if someone wanted to get really cute and figure from my log exactly what speed the truck is rolling, this lowers my average speed down a bit.
    Now, no one where I work does this, so it isn't a really big concern, but as much as possible I like to keep the average speed down, and if I am running 5 miles over and make no stops, then that might show when a DOT guy checks logs.
  10. MACK E-6
    49,916
    237,087
    The important thing is everything matching up such as toll and fuel records, and your average speed not being too high.
  11. GreenPete359
    GreenPete359 Road Train Member
    2,228
    5,333
    Oct 21, 2017
    Driving my recliner
    Ahhhhhh the days of paper logs...
