Radiator fan randomly going on
Discussion in 'Ask An Owner Operator' started by GYPSY65, Apr 9, 2025.
  1. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    2019 Pete 579 Paccar mx13
    fan will randomly go on while driving and stay on for 15-20 minutes or so. Then off for maybe an hour or ??
    not running hot or pulling hard. Actually does it flatland and empty
    any thoughts?
    Magoo1968 Thanks this.
  3. Ridgeline
    22,720
    123,260
    Is your a/c on or are you using your defroster?
    GYPSY65 Thanks this.
  4. Concorde
    Concorde Road Train Member
    5,479
    19,410
    Jun 29, 2016
    West Melbourne Florida
    Fan solenoid is failing and eventually your fan will just stay on.
    When I did mine it was relatively cheap and easy to do yourself.
    GYPSY65 and Magoo1968 Thank this.
  5. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,477
    Mar 18, 2021
    St Malo mb
    On my freightliner the Parksmart system causes it to go on. If I leave heat on low fan speed max heat it doesn’t cause the fan to randomly come on for no reason. In summer it’s never a issue only winter/springtime for some reason.
  6. Long FLD
    Long FLD Road Train Member
    12,850
    53,780
    Mar 4, 2015
    Possibly intake air temp sensor too.
  7. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Wiggle and pull test the wiring at the fan solenoid on the firewall driver side. Pins can get spread and copper can also break inside the insulation.
    I agree sometimes replacing the solenoid and just repinning the connector would be a good place to start.
  8. Arctic_fox
    4,508
    25,453
    Sep 16, 2016
    @Goodysnap beat me to it. That gods #### solenoid is crap and the connector is worse. I had 3 go out on my 579 and it usually took the air temp sensor with it. Id start there and just have the connector replaced. It costs more but the repins never lasted more then a month or two before it went back in when they failed.
  9. RunningAces
    RunningAces Road Train Member
    1,304
    2,581
    Jul 2, 2017
    If you turn your AC on and the radiator fan comes on what does it mean?
  10. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    It means the high side AC pressure has met conditions for cooling needed across the condenser and is part of normal AC operation.
    SL3406, GYPSY65 and RunningAces Thank this.
  11. GYPSY65
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    neither
    Sorry. I was off and forgot to check in
