Radio
Discussion in 'International Forum' started by down south, Jun 30, 2018.
  1. down south
    down south Bobtail Member
    37
    6
    Nov 4, 2016
    i have 2007 9400I International key on engine not running popping static in Cb
    Voltage falls down to 12.5 on acceleration
    Noise gets louder but does with engine running and key switch off all grounds cleaned antennas changed as well as radio key switch off doesn’t make straight to battery
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    Are you getting low voltage anywhere else in the cab under acceleration? CB is powered from fuse/breaker F5-B. Check your voltage there. The CB ground is at the cab stud in behind the dash on the right side. It would be in behind the breaker panel. Check for any corrosion. Also, check the basics, try a different radio and mic if you can.
    down south Thanks this.
  4. Lazer
    Lazer Road Train Member
    1,839
    2,967
    Jan 22, 2017
    You are picking up static from the electrical harness of the valve train. Typical IH
  5. down south
    37
    6
    Nov 4, 2016
    I changed everything in battery box cleaned every ground outside the truck. I ran Cb to batter then changed ground to chassis the engine does not have to be running to hear popping static or noise what ever you want to call it. Just ignition switch in run mode doesn’t do it in acc mode heavy D has helped. Me a lot over the years gonna have find him buy him lunch anyway all help is appreciated
    Heavyd Thanks this.
  6. down south
    37
    6
    Nov 4, 2016
    Also wouldn’t you have to run engine to pick up engine ststidc
  7. down south
    37
    6
    Nov 4, 2016
    Static is what I meant
    Bean Jr. Thanks this.
  8. Heavyd
    7,826
    6,275
    Feb 4, 2009
    Do you have fridge or power inverter, or any other electrical accessories running?
  9. down south
    37
    6
    Nov 4, 2016
    No engine off key off fine last night i cleaned all grounds again turn key on I call it popping static I have a power filter in line to I have a Wilson and new coax and a 102 whip trying different things
  10. Ridgeline
    22,701
    122,214
    A few things.
    First the voltage dropping means an alternator issue, you need to check it by checking the voltage at the batteries while accelerating, it you see a drop there, then you will need to look at the power cable to the alternator and the ground at it. May have to replace it.
    Second is static. It is coming into the radio only two ways, the first is through the power line and the other through the antenna. When you put a filter on the power (and not all filters work by the way) and still there then it could be the antenna and a good indication of a ground problem with the antenna and coax. IT is a bit different than a power ground and there is something that is called a Common Mode Current issue that happens a lot with trucks.
    See this link for a good explanation - Common mode current
