Railing a tractor
Discussion in 'Peterbilt Forum' started by Loaderlou, Jan 5, 2022.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi friends. I’m interested in replacing my frame rails in my 2003 Pete. I have a chance to grab a late model 579 single frame chassis to replace my double frame. Without putting them up against each other and comparing, I’m wondering if they would be compatible with each other. Any chassis gurus out there that can offer some advice?
  3. Cat sdp
    Cat sdp . .
    21,292
    76,094
    Apr 8, 2012
    Orion's Belt
    There’s an outfit in VT that will send you exact replacements holes drilled and everything……I forget the name but I’ll look…..
    Roger McG and Bean Jr. Thank this.
  4. rogermunn1
    rogermunn1 Light Load Member
    53
    61
    Dec 17, 2017
    NewBrunswick
    Are the inside frame rails you have good enough to go inside the frame rails you want to use . Your gonna hate a single frame after running a double frame . The outside measurement of the frame will be identical but the inside will be different and the crossmembers all shorter to make up for the width of frame rails inside
  5. Cat sdp
    Cat sdp . .
    21,292
    76,094
    Apr 8, 2012
    Orion's Belt
    BennysPennys, AModelCat and Roger McG Thank this.
  6. Lazer
    Lazer Road Train Member
    1,848
    2,978
    Jan 22, 2017
    Had an assigned company truck about 4 years ago that developed a frame crack between the tandems. Pete, long nose straight truck. Company claims it would be nearly $30,000 to replace that one side. They refused to have it welded. Sad, it was a really nice, powerful truck. Had less than 100,000 miles on it.
    Reason for edit: Correction
  7. Loaderlou
    342
    131
    Feb 24, 2014
    Yes I know of these guys. Got a quote from them last year of about 10k for both rails
  8. Loaderlou
    342
    131
    Feb 24, 2014
    Hi Roger. My rails are separating because of all the years of running salt and the road conditions from the salted roads. Many of my friends have purchased late model tractors with single frames and aren’t having any issues “yet”.
  9. Cat sdp
    Cat sdp . .
    21,292
    76,094
    Apr 8, 2012
    Orion's Belt
    Most guys around me are going heavy single frame…… but over a certain length you gotta do inserts or full double
  10. rogermunn1
    53
    61
    Dec 17, 2017
    NewBrunswick
    I haul upwards of 154000 lbs . ill stick with double frame
