Rain improve receive?
Discussion in 'CB Radio Forum' started by Lime Hauler, Nov 1, 2018.
  1. Lime Hauler
    Lime Hauler Bobtail Member
    22
    14
    Jan 30, 2018
    Middle TN
    My radio pulls in alot of static noise but when Im driving in the rain it receives perfect. Does anyone know why this may be?
    rabbiporkchop Thanks this.
  3. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Be willing to bet, if you check SWR when it's raining you'll find its threw the roof...I had a similar problem with my pick-up...when it rained I noticed the receive got real quite...checked SWR and it was pegging 3+... was loosing ground. ..had to make some changes to my antenna mount...Noticed yesterday when it was pouring again, no more problems.
    Lime Hauler Thanks this.
  4. VolvoTerry
    VolvoTerry Light Load Member
    293
    377
    Sep 7, 2015
    Based out of Omaha,NE
    While the scenario that JesseJames outlined could be correct, the exact opposite can be as well. By that i mean there may be an existing loose ground and the rain completes the grounding issue temporarily.
  5. Lime Hauler
    22
    14
    Jan 30, 2018
    Middle TN
    My swr is good, what steps can I take to solve the grounding issue?
  6. VolvoTerry
    293
    377
    Sep 7, 2015
    Depends on the mount, location of the antenna etc. What kind of truck? West coast mirrors ground can be improved by running a ground strap from the door to the cab to the frame.
  7. Ridgeline
    22,718
    122,941
    It is mostly because the noise that is created by static electricity all around you and is absorb by the moisture from the rain - much of it is eliminated. You hear static electricity as atmospheric noise in the radio, seeing it is AM (or SSB), the noise is not filtered out and become part of the noise floor which can be as high as 20 over S9.
  8. Lime Hauler
    22
    14
    Jan 30, 2018
    Middle TN
    Pete 379, mount is custom made to the truck above rear glass (daycab)
  9. hayseed
    hayseed Light Load Member
    211
    109
    Dec 31, 2011
    The Natural State
    run a piece of 1/16 stainless steel cable from a shock mount bolt to where it barely drags the ground. Just like you see the tankers running rubber straps only us cable. Made a huge difference in my "white noise"
  10. Cattleman84
    Cattleman84 Road Train Member
    10,003
    71,357
    Nov 1, 2017
    The Sticks, Idaho
    This also makes a great static ground to prevent a static discharge that can ignite a brush or stubble fire if you get offroad or into grain fields.
  11. rabbiporkchop
    9,689
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Sounds perfectly normal.
    Enjoy while you can.
