Ratchet Straps
Discussion in 'Flatbed Trucking Forum' started by crackinwise, Oct 18, 2014.
  1. crackinwise
    crackinwise Medium Load Member
    479
    238
    Aug 21, 2011
    Central Florida
    Anyone know how long and wide of a strap I need to do an X strap on the ends of flatbed loads? Especially the high loads.. Looks like it need to be a pretty long strap.
  3. ThatFlatbedGuy2013
    ThatFlatbedGuy2013 Medium Load Member
    591
    119
    Feb 4, 2013
    Somewhere in the US of A
    Regular standard 2 inch straps will work but you can also just use the 4 inches and use the....wutchamacallits
    crackinwise Thanks this.
  4. nikmirbre
    nikmirbre Road Train Member
    5,584
    10,335
    Jul 27, 2011
    High Point NC
    regular 27 or 30ft strap is plenty…….width of strap really not an issue
  5. n3ss
    n3ss Heavy Load Member
    737
    340
    Nov 4, 2013
    I've used 4"/30ft straps with no problems.
  6. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,163
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    If you get the flat hook straps, you can hook them together and wrap a layer of Duct tape around the joint. Had to do that plenty of times when tarping an OD load. Ratchet on either end also provides more even pressure vs pulling on just one end.
    Martin
    MJ1657, 281ric, mg1224 and 1 other person Thank this.
  7. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    People really X strap? Voluntarily?
    barroll Thanks this.
  8. jsprocket
    jsprocket Heavy Load Member
    830
    262
    Nov 4, 2013
    Columbus, GA
    Go get you some foam insulation and slam the brakes hard once, you'll wish you had. Can't make that stuff tight.
  9. Ruthless
    Ruthless Road Train Member
    9,163
    90,951
    Aug 28, 2010
    The City.
    Well having hauled foam for years: you slamming on the brakes with it is a decision you make-it tends to walk off the back without a chase strap (2' off the bottom around the back) or a single angled strap (catching both top units a little bit, this way is better). The center and front units I've never had move as I put a half twist and I tighten Til each strap is tight. They cut a ton. Of those slabs on the roof anyway, never had a claim nor heard of one for strap crush damage as long as you limit it to the top sheet of each unit.
  10. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    Not voluntarily. The load tells me when I have to :)
  11. leftlanetruckin
    3,607
    3,163
    Mar 12, 2009
    Slamming on the brakes is a "decision you make"?
    Like last week crossing into Illinois on 80, come up to the bridge, nada. Going up the slight incline, nada. get to the top and find traffic at a dead stop, yep. Yeah, I made the "decision" to slam on my brakes vs rearending the idiots that had all stopped for some reason. Nothing on the CB, no warning at all.
    I guess I am picky as I make 110% sure nothing can slide forward on my trailer, regardless of hard braking. I know hauling 50-70,000 lb machines may be different than insulation boards, lumber, loose pipe, etc, but the principal is still the same. Last thing I need is to add to the cluster....
    Martin
    jsprocket Thanks this.
