Rates
Discussion in 'Ask An Owner Operator' started by truckvet, Nov 18, 2021.
  1. truckvet
    truckvet Bobtail Member
    8
    4
    Nov 18, 2021
    Are there any free resources I can use to make sure I am getting a good rate?
    I am a new O/O and received what i think is a good rate. It was offered off top from the broker so I did not negotiate anything. However, with this route I have to go through mountains, up steep hills, and there will soon be snow. I am thinking I may need to negotiate more pay, but I'm not sure how much more and what to base it on.
    Also, for working Holidays, should I be asking for more? and how much more is reasonable
  3. bad-luck
    bad-luck Road Train Member
    3,415
    6,280
    Nov 16, 2013
    Baltimore, Maryland
    Loadboards have the average rate for the lane. It costs more than the standard membership.
  4. truckvet
    8
    4
    Nov 18, 2021
    Thanks! and do those take into account weather and Holidays?
    feldsforever and shooter19802003 Thank this.
  5. Short Fuse EOD
    2,789
    8,753
    Jul 29, 2015
    Midwest
    Dat gives last 2 or 4 weeks, depending on subscription. Weather and holidays…Just as any reason- it is up to you to determine your negotiation. Resources such as DAT are just a guide and do not factor special circumstances.
  6. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    It's crazy to let some random algorithm dictate your rates. You're the motor carrier. Run for what you need or don't haul it.
    WannaGoTrucks2016 Thanks this.
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    The "average" rates on ITS are a joke. Saw one yesterday. It was identical in every way and posted twice by the same broker. The bs number ITS was claiming to be the "rate" was almost $300 different.
  8. Ridgeline
    22,702
    122,301
    Here is the foundation to what you should be asking for …
    How much does it cost you to run the truck?
    WannaGoTrucks2016 and LoneRanger Thank this.
  9. LoneRanger
    LoneRanger Road Train Member
    3,695
    9,605
    Jun 3, 2018
    @Ridgeline is right. First get your numbers this includes how much you want hourly.
    now cost to run your truck + hour to throw chains on and hour to take off.
    you now have a base rate of what you need to survive. What is on top of that is profit. Make sure you include your salary In your base rate.
  10. bad-luck
    3,415
    6,280
    Nov 16, 2013
    Baltimore, Maryland
    Could be. I have DAT I don't have the premium plan, but they had the premium plan for a month for free. And on the top it had the average for the past 90 days. It was actually accurate for the area I was running.
    shooter19802003 Thanks this.
  11. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    I heard that before about DAT. Maybe they're a little better than ITS. Too bad DAT doesn't have as much flatbed posts as ITS. ITS has become practically unusable for me. It's so bad I'm considering closing the account at the end of the year.
    GYPSY65, xsetra and shooter19802003 Thank this.
