Ratio
Discussion in 'Ask An Owner Operator' started by teamscanada, Dec 7, 2023.
  1. teamscanada
    teamscanada Bobtail Member
    15
    Jul 21, 2021
    What’s better fuel miles on Volvo truck
    307 ratio
    Or
    355 ratio
    both are auto iShift
    with 485 Volvo engine
    2011
  3. Arctic_fox
    4,506
    25,420
    Sep 16, 2016
    Depends. Are you going to be in the mountains a lot or just on flat roads? As a general rule, Higher gears (lower number) typically have a lower RPM and will get better MPG on flatlands but are going to be rougher in the hills. Lower (bigger number) gears tend to be better in the mountains or if your always heavy as the engine wont need to work as hard.
    Theres some variation in there of course but you honestly wont notice a huge diffrence between 3.07 and 3.55 most of the time. But i also mostly do vocational with a manual and know very little about volvos overall. That said the 3.55 are a pretty common choice for a reason. Namely they give a good well rounded result. 3.28s are also fairly common if you can find them.
    Big Road Skateboard Thanks this.
  4. Espressolane
    18,662
    116,927
    It is more of a package. Knowing the transmission ratios and final is just as important.
    you can put a 3:08 or. 3:55 in the differential.
    The 3:08 will be best with a direct output, the 3:55 would be better suited to an overdrive.
    Big Road Skateboard and Hammer166 Thank this.
  5. teamscanada
    15
    Jul 21, 2021
    I want to save fuel …I heard 264 ratio are better but my options is 307 or 355
  6. Hammer166
    7,601
    27,764
    Aug 18, 2007
    ~8600+' and loving it!
    Tire size matters, too. I'm running 3.08 with 13 over but tires are only 36" tall. That's equivalent to 3.55's on tall rubber.
  7. Big Road Skateboard
    7,085
    40,161
    May 2, 2021
    Good for you. Now answer the question @Arctic_fox asked, otherwise, everybody's just guessin
  8. teamscanada
    15
    Jul 21, 2021
    24.5 and 12 speed auto 2612 tranny I’ll be using it on flat
  9. Long FLD
    Long FLD Road Train Member
    12,842
    53,735
    Mar 4, 2015
    What’s the torque curve on a 2011 Volvo engine? Is it designed to be run at 1000-1200rpm or do you need to be cruising at a higher rpm? What speed do you want to cruise at? What’s the final ratio on the transmission? Which rear end will put you at the best rpm at the speed you want to cruise at? Lots of things to think about other than just rear end ratio.
    Oxbow Thanks this.
  10. RockinChair
    RockinChair Road Train Member
    5,353
    14,280
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Will you be on the Interstate, or doing a lot of stopping and starting?
  11. Mr Uturn
    Mr Uturn Light Load Member
    201
    236
    Jul 30, 2021
    307 and 68mph or less
    Without knowing all the other important stuff.
    Rideandrepair Thanks this.
