Rear End Change Question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cornbread914, Apr 8, 2022.
  1. Cornbread914
    Cornbread914 Bobtail Member
    20
    15
    Apr 8, 2022
    I have a 99 Peterbilt 379 with a 3406E CAT, 13 spd and 3:70 rears. I get just a hair over 5 mpg. Truck pulls great, but was thinking of swapping to 3:55 rears. How much, if any, would this change my fuel economy and power?? Thanks
    Oxbow Thanks this.
  3. Big Road Skateboard
    7,079
    40,108
    May 2, 2021
    What RPM are you normally running at? What size tires?
    Oxbow and Last Call Thank this.
  4. Cornbread914
    20
    15
    Apr 8, 2022
    I’m running 1550 at 70mph. I run 11R24.5
    Oxbow and Big Road Skateboard Thank this.
  5. Big Road Skateboard
    7,079
    40,108
    May 2, 2021
    3.36 may be your best bet with your engine.
    Diesel Dave and Swine hauler Thank this.
  6. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    Are you on low pros ? Because I was set up like that with a B model and 1550 rpms was a true 78 mph
    I just switched to 3:36..haven’t tried it out yet.. but Iam on tall rubber
    Coffey, Oxbow and Swine hauler Thank this.
  7. Cornbread914
    20
    15
    Apr 8, 2022
    I’m on tall rubber. 11R24.5
    Oxbow Thanks this.
  8. Cornbread914
    20
    15
    Apr 8, 2022
    Isn’t there quite a bit of difference between the 2? How much difference in pulling power would that be? I pull emulsions in summer on a lot of county roads. I’m in Tennessee in hill country, don’t want to hit a hill and have it fall on its face.
  9. wore out
    wore out Numbered Classic
    17,294
    214,375
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    None is what it will change it. You can say lower rpm equals better mileage till hell comes home. You can say sweet spot this or that but from personal experience I can tell you it will not change.
    Make sure your motor is performing at its best. Absolutely no boost leaks, no air in fuel system, over head properly adjusted etc. I get that you may be making x lbs of boost etc however that doesn’t indicate you don’t have problems.
    I have been from 3.36 to 3.70 to 3.55 with the same truck. I pulled hills at same speed with all of them, fuel consumption never changed, only thing that changed was what gear I pulled x hill in. I get it on paper it looks good but in the real world it’s not worth the money. All that said I like my 3.55 best. I run 11R24.5 with a RTLO18913A trans. With them I can split down to 12th and still run 65 out on a 2 lane with a hard crosswind. The 3.70 I got a little gear bound in that situation at times. With the 3.36 high gear was just too high to use so I was turning my auxiliary all the time.
    take it for what it worth
  10. J.R.
    J.R. Light Load Member
    65
    184
    May 17, 2012
    WI
    I concur, went from 3:55 to 3:70 l.p. 24.5. Thinking it would pull hills better? Nope just a different gear.
  11. Swine hauler
    Swine hauler Medium Load Member
    349
    2,245
    Jun 21, 2019
    No.
    Your motor is making the power.....not your rear gears.
    If you swap your rears you will only change your start ability (1 gear, getting started), and your top speed at a given RPM. All other driving will be in a half gear lower (less than that actually, going from 3.70 to only 3.55). In other words hitting a hill you may pull it in 8th instead of 9th. Etc.......... Your power stays constant, and it will only fall on its face if you fail to use your gearbox for it's intended purpose.
    What wore out said was correct. I just explained it a little differently . I think.
    Also, you may go slightly faster in reverse.
