Rear structure leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by earnies2, Nov 3, 2019.
  1. earnies2
    earnies2 Medium Load Member
    691
    281
    May 17, 2012
    Dedham, MA.
    2009 ISX Cummins rear structure leaking what should it cost to get fixed?
    It's in a 2009 international prostar with a 13 speed
  3. Dave_in_AZ
    422,509
    Rear structure? As in bell housing or rear main seal?
    If you're going to do one spend the few bucks and do both.
    buddyd157 Thanks this.
  4. 062
    062 Road Train Member
    6,321
    33,958
    Oct 20, 2013
    @Heavyd may have a idea on the cost.
  5. jamespmack
    216,469
    Well you not gonna do the rear structure with out a rear main so there is that. But good time for clutch, linkage and rear engine mounts. I prefer to do everything I can while its apart. Sucks to pull a trans for cross shafts after a clutch.
    4500.00 to 6000.00 parts and labor
    Deere hunter, wtokhi, KB3MMX and 4 others Thank this.
  6. Dave_in_AZ
    422,509
    I mean if it's the rear main seal, you could get away without messing with the bell housing.
    If it's the bell housing, replacing the rear main is seriously a few bucks more.
    But once you have it all apart like that, you're gonna hate yourself hugely if the bell housing gasket goes south on you.
    jamespmack and Rideandrepair Thank this.
  7. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    I don't think it's the tear main seal it's not leaking from the inside of the bell housing it's running down the passenger side of the block at the bell housing.
    jamespmack Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,769
    9,190
    Jul 12, 2017
    Oil pan and rear crank seal all get redone with rear gear housing gasket. No choice.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Checked housing well for cracks and wear. I think @pushbroom said they have had good luck having local machine shop resurfacing the area that mates to the block surface.
  10. pushbroom
    pushbroom Road Train Member
    1,788
    7,394
    Sep 1, 2012
    Gasket is steel with a rubber sealing surface. The steel can fret into the aluminum housing. Our local machine shop machines both the front and rear structures for us with excellent results.
    Why dont you get a local shop to give you a quote for the work done? It varies in parts price, hours and labour rate depending on location.
  11. earnies2
    691
    281
    May 17, 2012
    Dedham, MA.
    I think I will pull my dog house and see ware its leaking from
