Rear u bolts question.
Discussion in 'Volvo Forum' started by ErieMcDreary, Mar 29, 2020.
  1. ErieMcDreary
    ErieMcDreary Medium Load Member
    460
    393
    Dec 4, 2016
    Erie PA
    While doing some maintenance on my truck I found a loose U bolt on the forward differential. When I tried to tighten it I got a rude surprise. They don't have normal nuts!!! They look like round sleeves instead?!?!
    Is my only option replacing them?
  3. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,896
    Sep 20, 2015
    Southern Ontario
    What truck is this?
    I’ve never heard of a huck nut being used for u-bolts.
    Bean Jr., Rideandrepair, PE_T and 2 others Thank this.
  4. Shawn2130
    896
    1,896
    Sep 20, 2015
    Southern Ontario
    If that’s the case, the only way is to replace the u-bolts.
    Bean Jr., Rideandrepair and Dino soar Thank this.
  5. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    It's a 2106 Volvo VNL, Volvo air ride tandem.
    Shawn2130 Thanks this.
  6. Rideandrepair
    17,442
    56,579
    Aug 8, 2015
    Once a u bolt is loose, it must be replaced, and torqued properly to attain proper stretch. Even if you could tighten it, it won’t hold, will loosen again, because u bolts are already stretched.
  7. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    OK, thanks. Off to Volvo in the morning.
  8. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Ask Volvo to check pinion angle as it going out of spec when U-bolts are lose. Otherwise drive line vibration will destroy everything slowly but steady.
    Rideandrepair and PE_T Thank this.
  9. 062
    062 Road Train Member
    6,283
    33,794
    Oct 20, 2013
    Hopefully you have access to a torch or know someone who does.
    Rideandrepair, 6wheeler and Chubby Fly Thank this.
  10. ErieMcDreary
    460
    393
    Dec 4, 2016
    Erie PA
    Yes I have one, but I don't have a heavy duty impact to tighten the new ones enough.
    Volvo wanted to re-install the same thing, I said NO WAY!!!!
    Local alignment and suspension shop doing it Thursday. All new U-bolts and re-alignment.
    Rideandrepair, Shawn2130 and 062 Thank this.
  11. Shawn2130
    896
    1,896
    Sep 20, 2015
    Southern Ontario
    There really is nothing wrong with using Huck bolts and nuts.
    Those machines put the preload on the bolts the first time and compress the nut in place.
    I have learned myself that u-bolts should be replaced any time they come loose or are removed.
    As time goes on, the nuts seize in place and the threads that are visible to the salt and weather are usually rotted away.
    I have tried re tightening u-bolts for one truck that we have but it’s difficult to get the proper torque specs again.
    End up being better in the long run to just replace them.
    Bean Jr. and Rideandrepair Thank this.
