Rear wheels locking Up
Discussion in 'International Forum' started by Rookie2022, Mar 5, 2022.
  1. Rookie2022
    Rookie2022 Bobtail Member
    4
    Oct 7, 2021
    I have a 2016 international prostar and the rear wheels are locking up when turning, backing or driving afwater a stop. Lots of smoke from the wheels. One mechanic recommended I change all 8 tires so they match ( since I changed last 4 ) should I change the tires or take it to international dealer? What do you guys think?
  3. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    Changing tires won't fix your problem.
    Shawn2130 and Opendeckin Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I recommend this be towed to shop for further examination. Something is jamming up there with either the gear itself or the brakes. Either way, sounds unsafe to drive.
  5. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    Sounds like the breaks are not releasing/ hanging up after you stop. Could be a bad air valve.
  6. Rookie2022
    4
    Oct 7, 2021
    Shop opens Monday will keep you guys updated on what they say.
  7. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Could have bad s cam bushings, slack adjuster not releasing, when was last time foundation brakes were serviced, greased?. how much lining thickness on brakes?.
    did the S cam “cam over” brake spider securely mounted to axle housing?,
    Is s cam tube bracket still mounted to axle housing. All things you can inspect and do yourself.
