Rebuild help.. DD S60
Discussion in 'Freightliner Forum' started by CaGaMo, Mar 10, 2013.
  1. CaGaMo
    CaGaMo Bobtail Member
    5
    Jan 28, 2012
    Hello group! I have an '05 Columbia with a Series 60 with over 1 million miles.. The motor is still doing pretty good. Horsepower (is at 78%) and mileage is down, but no other big issues (blow by, oil consumption, etc..) except for EGR leaks and a Delta Pressure sensor that keeps plugging up and going out of calibration.. But now, my EGR cooler has decided to develop a hole in it. The shop wants $1800 for that, so I figured why not just take it to Detroit for a rebuild since it is over a million miles.. So my question really should be.. Which rebuild to do? I'm thinking a Step 2 with added injectors, (my current injectors are 4 years old this month, and my turbo just turned 2). I would do a full Step 3 but that's just a bit beyond my current finances..
  3. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
  4. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    It's a fresh start. If not running Cali why not delete the egr?
  5. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Talk to detroit.
    Tree was commenting to me last night the Delta-P sensor has been deleted by detroit.
  6. sdaniel
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    What ever you do when they open her up , have the bull gear replaced.
  7. popcorn169
    popcorn169 Road Train Member
    2,194
    1,714
    Sep 5, 2011
    state of confusion
    The injectors can be tested by Detroit to see if they are fine. How much oil between oil changes is being used? I would not rebuild it just because the EGR I would delete that and be done with it. That is just my 2 cents worth,
  8. CaGaMo
    5
    Jan 28, 2012
    Just because new injectors were recommended by my local Detroit and Freightliner dealer..
  9. CaGaMo
    5
    Jan 28, 2012
    I would not only love to delete the egr, but any and all sensors and other such nosense.. I never plan on going back to Cali again..
  10. CaGaMo
    5
    Jan 28, 2012
    My local Detroit Dealer says that they can't bench test injectors, so I would really be taking advice from a shop that sells them.. I only go thru 1 gallon of oil between oil changes, and when I need that gallon, I just get a p/m..
    I would love to dump the EGR if I knew of a shop locally that could do the work.. I live near Springfield, MO..
  11. losttrucker
    losttrucker Road Train Member
    1,436
    1,041
    Mar 9, 2008
    greenville,nc
    Will Detroit warranty the rebuild since it has over 1 million on the motor?? I know on their website it says No so you may wanna check and if they wont warranty it consider an outside shop
